TEA LUBE FRONT BEARINGS AND GREASE BOOT REPLACEMEN
Peter (ottawa)
03-15-2004 07:48:19
I took off my front wheels and noticed a threaded brass fitting behind the hub assembly. Do I remove the fitting and fill the space with grease in order to lube the bearings?? Or should I remove the bearings and re-pack??
My grease boots on the steering linkage are all shot, can you simply replace the boot or do you have to replace the linkage??
Thanks
Jim W
03-16-2004 16:00:50
 Re: TEA LUBE FRONT BEARINGS AND GREASE BOOT REPLAC in reply to Peter (ottawa), 03-15-2004 07:48:19
third party image
Where do you mean, regarding your first question?
Re: #2 - yes you can just replace the boots. If the tie rod ends, or drag link ends I guess they are in tractor-speak, are worn, you will be able to move the steering wheel with no corresponding movement of the front wheels.
Boots can be found at Canadian Tire or I think UAP/NAPA.
Peter (Ottawa)
03-16-2004 16:36:54
 Re: Re: TEA LUBE FRONT BEARINGS AND GREASE BOOT RE in reply to Jim W, 03-16-2004 16:00:50
Thanks Jim I'll look for the boots at CT.
Regarding #1:
The brass fitting is basically on the opposite side of the front wheel hubs . Maybe this sould be a grease fitting? The closest grease fitting is on the front axle , this grease fitting lubes the spindle assembly.
I was in your neck of the woods today, Hwy 15 from Carleton place to Smiths Falls. I was looking at a 5 foot grader blade that turns out to be made by Ferguson. It was in rough shape and was welded at the top plate, so the blade no longer rotates. It looked very heavy , I couldn't tell for sure as it was still frozen to the ground, but I would guess 200 maybe 300 pounds. Do you know if the TEA can easily handle this weigh??? If the TEA can handle it I'll buy as he only wants $75 for it.
Jim W
03-17-2004 04:35:26
 Re: Re: Re: TEA LUBE FRONT BEARINGS AND GREASE BOO in reply to Peter (Ottawa), 03-16-2004 16:36:54
The TEA can certainly lift this much. The pressure relief valve in the hydraulic system opens when you lift ~850 pounds, so no sweat.
You'll have fun manhandling it around but a heavy blade is a good thing and the price is right.
Jim
