Serial Number / Jim W
John of Ontario
03-14-2004 11:45:30
Hello Jim.Here is my tractor serial number from the plate above the steering wheel TEA 249801' still can't find the engine serial or transmission date code' not sure where to look.Bye for now. P.S Do you know where I could get a good used rear rim/wheel/tire to fit my ferguson. Tire size is 11.2-28 on a 10 inch rim .My tire and rim are pretty will shot.Thanks.
Jim W
03-14-2004 14:23:35
 Re: Serial Number / Jim W in reply to John of Ontario, 03-14-2004 11:45:30
third party image
Hi John,
The transmission serial number is cast into the housing just ahead of the dipstick.
To find the engine serial number take a look just to the right of the ignition coil, or you could say just to the left of the oil filler. You usually have to clean it off with steel wool or light sandpaper to see it.
Someone else asked me about rims just last week and I didn't know the answer then either, but I have seen them someplace om the web for sure. No doubt your local MF dealer could get them in for you at maximum $. Pretty common problem and I am thinking of "unloading" my rear tires before it's too late. Seems like the calcium mixture is supposed to stay in the tube but eventually leaks. Maybe it rots the valve stem.
I have changed about 8 of the rims and centre discs around and found that that part of the job isn't too hard. Well, yes it is hard. But I mean not complicated :) Be careful when undoing the bolts not to strip the threads - apply lots of heat to the nuts and proceed slowly.
Regards,
Jim
Ray,IN
03-14-2004 20:19:53
 Re: Re: Serial Number / Jim W in reply to Jim W, 03-14-2004 14:23:35
By the time you find a "good" used rear rim it'll cost nearly as much as a new reproduction rim from Miller Tire, one of the YT sponsors you'll find under the Marketplace links at the left.
Jeff-oh
03-15-2004 04:57:32
 Re: Re: Re: Serial Number / Jim W in reply to Ray,IN, 03-14-2004 20:19:53
Also try a your local tire shops that deal in farm tires. I got mine locally and saved 40% on total internet cost (price and shipping.)
Jeff
