TEA-20 Clutch pedal adjustment revisited
Dusty Dave
02-14-2000 16:02:33
This is a follow-up to an earlier post about adjusting the clutch pedal.
Well, there's nothing much to it, actually. The clamp-bolt and the squared-off shaft end are all 11/16" wrench sizes. I just loosened the clamp bolt, held up the now-loose pedal with a couple of sockets jammed under it, put a wrench onto the end of the shaft to make sure the clutch was about to be engaged, and tightened up the clamp on the pedal. It took a couple of tries, but now the pedal has a slight amount of freeplay before the clutch is engaged. And the result? It's about the same as before! But the clutch can often be heavy and fairly sharp on these old machines with coil-sprung pressure-plates. Oh well.
teadave
02-14-2000 19:42:11
 Re: TEA-20 Clutch pedal adjustment revisited in reply to Dusty Dave, 02-14-2000 16:02:33
were you surprised that the wrench size was 11/16"? from what i can tell there are only 2 sizes required on this tractor.
