Perkins A3.152
mf205
03-07-2004 14:15:25
I was restoring the engine in my Massey Ferguson 203. It is a Perkins A3.152. Now i am trying to get it running. When i start it turns over and runs with the starter motor but when i release the switch it dies. I put the timing gear together with the timing marks in order. What could be the problem.
RZ(Wa)
03-11-2004 10:46:55
 Re: Perkins A3.152 in reply to mf205, 03-07-2004 14:15:25
Yep, Bleed the fuel train again, from tank through the injectors completely and then bleed it a bit more. Getting all the air out of the injection pump is where I had my little frustration. As I recall, I had to go through the bleeding procedure about three times before I had good fuel flow.
rod
03-07-2004 19:42:14
I have a 203 with perkins diesel it is hard to get it bled out if out of fuel drop me an email I have the perkins engine manual and can scan the timing procedure and send it to you. email to [email protected]
regards
rod
Chris C.
03-07-2004 16:07:44
I know this may sound simplistic, but you should bleed the fuel injection system just like the manual states, from the lift pump down stream to the injectors. If you have already tried that I'll just shut up.
