TO-20 dies out unless choke is full on, why???
Tom
02-14-2000 07:17:25
Old faithful is acing up and won't run unless the choke is out, warm, cold no matter. I tore down the entire carb pulled the jets and blew out and soaked the entire thing and it runs the same. The only thing is that return spring on the choke lever is broken but that shouldn't matter if the rod is hooked up right? So whats the deal here????
ROGER
02-14-2000 11:52:06
 Re: TO-20 dies out unless choke is full on, why??? in reply to Tom, 02-14-2000 07:17:25
Same thing happened to my to35. I found that the main adjusting needle on the carb was out of adjustment. I turned it counter-clockwise about 1/4 turn and that did it. I hope your solution is as simple.
