steering column bearing on to30
brian
03-05-2004 05:43:29
On my 1953 to30 the steering wheel will pull up and down and is somewhat loose. Is this normal or is there something I need to fix/change? In the manuals it shows bearings on the top and bottom of the shaft.If I need to replace these how do I go about it and are these readily available.
Paul in AZ
03-05-2004 07:47:10
 Re: steering column bearing on to30 in reply to brian, 03-05-2004 05:43:29
Brian,
The MF/AGACO parts database shows that the bearings and the bearings cups are available from your dealer.
Paul
brian
03-05-2004 09:39:46
 Re: Re: steering column bearing on to30 in reply to Paul in AZ, 03-05-2004 07:47:10
How hard are these to replace?
Paul in AZ
03-05-2004 11:43:03
 Re: Re: Re: steering column bearing on to30 in reply to brian, 03-05-2004 09:39:46
They are not particularly difficult once you get the steering wheel off.
If you do not have Ferguson parts & service manuals, you should both. They will be helpful.
