Measurments for a Bumper / Brush Guard TO20
David - TX
03-04-2004 07:09:22
Any one have any measurements or plans for a front bumber for a TO20. I need to build a bumper / brush guard to protect the hood, grill and radioator while running my brush hog.
Fred OH
03-06-2004 11:31:33
 Re: Measurments for a Bumper / Brush Guard TO20 in reply to David - TX, 03-04-2004 07:09:22
Well, heres what I did to mine...I took a regular (probably aftermarket) bumper for a Ford tractor made from about 3 to 3.5" formed channel and two pieces of 1" X 2" X 7" steel and drilled two holes in them 5" apart to bolt the bumper on with. This puts the bumper 5" lower than in the original position...and it clears the open hood well. Just had to put longer bolts through the front axle. It looks decent and if I need anything to protect the radiator, I fabricate it and bolt it on with the hitch pin hole in the bumper. Generally speaking...a piece of screen tied to the headlights keeps the trash out of the radiator but...the fan on the 9N Ford tractor still sucked trash in through the bottom. A piece of foam rubber about 4" square and long enough to go across the bottom of the radiator stuffed into the opening completely stopped any trash from getting in. If you have a Ford, it's hood doesn't open and the only way you can clean it is with a water or air hose. Tough to do out in the field. I just went out and looked at the TO-20 and it looks like it will work on it too. The little formed piece that helps latch the hood open will hinder getting it in...but will also help to keep it in...or so it looks. My opinion is...you don't have to put up with the trash in the radiator if you engage your brain enough. One last thought...when you take your hand to clean off the accumulated trash on the screen in front of the radiator...use a glove...it's full of bugs and stickers. Fred OH
Tree Farmer
03-04-2004 18:27:54
I'd be interested in something like that also. Damaged my oil pan pretty bad last summer when running over 2" to 3" diameter Alder Brush in clumps. Lost my oil, but didn't damage the engine. Need something that would protect the pan also. Maybe I was too aggresive with the Bush Hog.
Ray,IN
03-04-2004 19:28:10
 Re: Re: Measurments for a Bumper / Brush Guard TO2 in reply to Tree Farmer, 03-04-2004 18:27:54
The original Harry Ferguson bumper (optional accessory) is made from 1/2" thick X 3" wide steel. It bolts to the axle on each side, with the front piece curved to match the curve of the hood, and extending about 4" further on each side past the mounting section. Any brush guard must be removable so the hood may pivot for servicing. Some bumpers may not look like what I described. The factory bumper was quite expensive for the times, so many dealers had bumpers made locally at a much lower cost. I'm sure mine is original because I was with Dad when he bought the (now my) tractor in 1953.
Ray,IN
03-04-2004 19:32:04
 Re: Re: Re: Measurments for a Bumper / Brush Guard in reply to Ray,IN, 03-04-2004 19:28:10
Hey! Brain surge- add your email address but check the hide option for privacy, and I'll email you a picture of the bumper.
Dennis West
03-07-2004 06:10:41
 Re: Re: Re: Re: Measurments for a Bumper / Brush G in reply to Ray,IN, 03-04-2004 19:32:04
Hi Ray,
I would appreciate a picture of your bumper, too. Thanks,
Dennis
David - TX
03-05-2004 06:13:16
A picture would be great. I can get an idea of what already works and add the skid plate and brush guard.
Thanks
[email protected]
51TO30 in Mo
03-05-2004 05:14:00
Ray,
I would like a picture as well if possible. [email protected]
I too need a bumper for my 51 TO30, no damage yet, but don't want any either.
Thanks!
