crank oil level
joe
03-03-2004 18:53:31
on my TO20 I drained the oil from crank via all three bottom plugs, put in 5 gallons of gl1 and nothing on the dipstick, opened the 2nd 5 gallon drum and guessed about another gallon which makes 6 total. still nothing on the dipstick, added more and still nothing on dipstick. My question is if 6 gallons is full, maybe my dipstick isnt original? about how many inches long is the dipstick, also, with the correct amount of oil in the crank, when you look down into the filler port by the shift lever, how far down is the top of the oil, is it above the rods and stuff that you see in there? about how far down to the top of the oil level would you say?
Thanks for your input!
-joe
marlowe
03-03-2004 20:04:10
 Re: crank oil level in reply to joe, 03-03-2004 18:53:31
when you dump oil in the fill hole it takes some time for it to get to the chamber of the dip stick holes are kind of small just give it some time but 6 gal. will fill it. then run it and then let sit and check should be full a little over is ok
phil fenner
03-03-2004 19:06:57
Joe, the oil level for the transmission/hydraulic pump cavity/rear end should be full when removing the bottom bolt of the inspection cover with the dip stick and the oil JUST starting to leak out. This way will remove any concern over the dipstick length. It would then be nice to calibrate your dip stick at that time.
Phil(WA)
