tire chains
DavePA
02-29-2004 13:48:26
Have been watching auctions for rear tire chains, of course when they are sold seldom the size is given. So, what would the length and width of chains to fit 12.4 x 28 tires be if they were laid out flat on the ground? thanks Dave
Jim W
03-02-2004 05:00:41
 Re: tire chains in reply to DavePA, 02-29-2004 13:48:26
It's really hard to answer because different sets are different widths i.e. some wrap around the tire more than others.
In my opinion the wider ones are better, and, if they are too long, it is easy to shorten them. Not much of an answer maybe but just to say you might have more flexibility than you thought.
JIm
danct
03-03-2004 07:34:24
 Re: Re: tire chains in reply to Jim W, 03-02-2004 05:00:41
Jim is right,i made a set out of old school bus chains i found in the junk yard,i fasten them with rubber cords i bought from Mill Supply who supply snow plow parts i put aprox 10 on each side and can travel on the roads short distance withh no looseness,when i take them off i will give you the exact measurements if you like
good luck
Danny
DavePA
03-04-2004 12:55:23
 Re: Re: Re: tire chains in reply to danct, 03-03-2004 07:34:24
Yes please, the measurments will be helpful and greatly appreciated. thanks Dave
danct
03-14-2004 09:10:07
 Re: Re: Re: Re: tire chains in reply to DavePA, 03-04-2004 12:55:23
Dave
i took off my chains today ,they measure 136 inches long by 16 inches wide my tire size is 12.4 x28 ,i use 12 rubber straps on each side and if you space them right you get rid of all the looseness , these work great for me on the 1952 to30 i plow with good luck
Danny
DavePA
03-14-2004 13:01:28
 Re: Re: Re: Re: Re: tire chains in reply to danct, 03-14-2004 09:10:07
Thanks so much for the information, the spring farm sales ar starting to pop up..Hopefully I can run into a set. Dave
DavePA
03-02-2004 06:48:37
thanks for the response, looking for a size at least in the ball park so at least I do not get stuck with chains I can not adapt to fit. thanks Dave
