front tire size and temperature
Michael
02-28-2004 22:03:39
What is the largest front tire size I can put on my TO 30? I have 5.50X16 now. I would like 6.50 or larger if possible. Also, I know engine blocks had trouble with cracking. Mine is cracked and has already been pinned. I have had no problems. I am wondering what is "too hot." The tractor never seems to get really warm according to the temperature guage. The guage is brand new. Just wondering. Thanks
Ray,IN
02-29-2004 20:58:11
 Re: front tire size and temperature in reply to Michael, 02-28-2004 22:03:39
600x16 is the optional tire size listed in the owners manual for a TO30,35,MF135, and some other models. The temperature gauge cannot detect hot spots in the block if one or two passages are plugged, it transmits the temperature of the coolant where the sender is located only, leaving the radiator to mix and radiate heat from the system as a whole. This could allow hot spots at just the right place, explaining cracked blocks without the heat gauge warning the operator in advance. This falls back on the requirement for proper and timely maintence. Have you installed a new thermostat, back flushed the cooling system? Internal combustion engines must sustain the correct temperature(>160*F in this case) for efficient operation. Some remove the thermostat thinking they help the engine run cooler, and it does, to the detrement of engine longevity and fuel consumption. I hope my opinions are useful to you.
