TED20 Roll Bar (ROPS)
Dave (Bonnie S
02-25-2004 04:08:34
Hi all
My first post here but have been lurking and picking up loads of useful tips since getting our TED20 (TVO model) a couple of months back. Thanks all - particularly the TVO recipes which seems a bit like witchcraft to me.
We got the Fergie specifically for carting logs and pulling stumps from our very overgrown (ex Forestry Commission)9 acres of larch woods. Hadn't realised that lack of ROPS meant we were breaking UK law! However, I'm now more worried about breaking necks :-)
Can only find one supplier for ROPS and they're quoting �250 - yikes - that's half what the tractor cost. Does anyone have some decent photos/dimensions detailing the fixing points and rough steelwork sizes so that I can get the local smithy to fabricate something from box section and plate that will do the same job?
Will be interesting to see if a ROPS is a hinderance when trailing in and out of woods - all those low slung branches that we can currently avoid.
Great site and hope to be back here often.
cheers
Dave
Ali,fae Crieff
02-25-2004 12:09:19
 Re: TED20 Roll Bar (ROPS) in reply to Dave (Bonnie Scotland), 02-25-2004 04:08:34
Hi Dave, I think the ROPS requirements are based on the Health & Safety at"WORK", therefore if your wood clearance is private or recreational then I don't think they apply, though having said this a roll bar is definately a sensible thing to have.Do bear in mind that Thomas is right in that to be any use a roll bar would have had to have been designed accordingly,your local blacksmith can only copy one in hope,however, I have a roll bar I took off my 65 and it is kitemarked and adjustable to fit various tractors including the TE 20 so I can only imagine that the axle is deemed strong enough. Cheers, Ali.
Thomas
02-25-2004 11:33:41
�250 sounds quite cheap if it's an approved ROPS. I don't know the wording of the law but I assume that a ROPS fitted has to be approved to the relevant ISO standard and that means that one will have to be tested. This is quite expensive to do so ROPS frames are not cheap. Check HSE website?
Steve Mo
02-25-2004 11:31:07
Just a note as I was looking into this also. I was just going to have a local welder make one up for me then I noticed a post concerned that the rear axel was designed to cary a ROPS at all. Not much point to using one if it just breaks when needed.
03-15-2004 14:53:45
 Re: Re: TED20 Roll Bar (ROPS) in reply to Steve Mo, 02-25-2004 11:31:07
Thanks for the replies folx.
And thanks Ali for the roll bar - reasonably priced AND delivered - what more could one want! One of the benefits of living in a country you can drive across in one day :-)
Manufacturers plate on roll-bar leg states that it is suitable for TE 20 so I'm confident it'll fit and do the job it was designed for - but hope I never have to see it in action.
Ah weel.....now where's that wire brush and tin of hammerite?
