Wheel Weights ???
John of Ontario
02-16-2004 18:48:20
Hello Folks. Do they make front wheel weights for my 20-85.Did ferguson make them,or was it after market items.It would be nice to get some when I do bush work like skidding.
TO35
02-17-2004 03:04:38
 Re: Wheel Weights ??? in reply to John of Ontario, 02-16-2004 18:48:20
third party image
John, here's a picture of my orignal to35 wheel weights. They tell me these one piece are getting hard to find but I have run across a few sets in slavage yards they usually go for a hundred dollars a set here.
best wishes
TO
Ray,IN
02-16-2004 20:28:56
MY TO30 equipted with 6.00-16" front tires has a set of orginal H.Ferguson two piece weights. They have two holes in each half to bolt to the rim(=4 holes in rim). If you have 16" rims perhaps you can locate a set of weights at a salvage yard.
Jim W
02-16-2004 21:14:08
 Re: Re: Wheel Weights ??? in reply to Ray,IN, 02-16-2004 20:28:56
Ray, you have a picture of those by any chance? I have the same rims you describe, am thinking it might be possible to make a set.
Thanks,
Jim
Ray,IN
02-17-2004 18:38:20
 Re: Re: Re: Wheel Weights ??? in reply to Jim W, 02-16-2004 21:14:08
Jim, send me an email and I'll use your address to send a photo of the mounted weights. They fit inside the rims, and must be removed prior to removing the rim from the tractor; then must be attached after mounting the rim on the spindle. This is a pain when you have a flat tire, but the weights are worth the trouble.
Jim W
02-18-2004 04:56:06
 Re: Re: Re: Re: Wheel Weights ??? in reply to Ray,IN, 02-17-2004 18:38:20
Hi Ray,
Please email me at wallaces at superaje dot com.
Thanks,
Jim
Peter
02-17-2004 10:09:44
Could you not simply load the front tires with calcium as is done with the rear tires???
