Timing - not according to manual ?
Phil-Australia
02-16-2004 01:08:15
I'm very close to getting my TED20 1951, running sweet. I have set the timing according to the manual (align hole in flywheel & casing and set points to just open) but it still misses and backfires under light load. Works fine when under load.
I have been experimenting and advancing the timing improves the running immensley but this is experimentation and guesswork and not according to the manual. Am I missing something in setting the timing up. The engine serial is S174533E
Carby refurbished and fuel flow is fine.
Any advice appreciated
Phil
Ed TN
02-16-2004 19:24:26
 Re: Timing - not according to manual ? in reply to Phil-Australia, 02-16-2004 01:08:15
Sounds like you're sucking air somewhere. You said carb was refurbished; did you replace the throttle plate shaft and bushing? That's first place to look.
Jerry/MT
02-16-2004 17:53:27
Phil,
Are you sure that #1 Cylinder is on the compression stroke when you set the timing. The timing marksline up on the exhaust stroke and on the compression stroke. You need to make sure that the #1 piston is on the compression stroke when you set the timing. You can verify that by removing the #1 plug and while someone cranks the engine over you can put your finger over the #1 spark plug hole. You'll feel the pressure build up on the compression stroke. Then set the timing mark to the correct position. Your rotor should be pointed at the #1 plug. (If it's not make sure your high tension wires are placed in the correct firing order.)Take a bent piece of wire and put in in the sparkplug end of the plug wire. Turn the key on and holding the #1 spark plug wire with the piece of wire in it to a good ground, rotate the distributor til you hear the snap of spark. At that point you are statically timed. It takes a few times to get it just right. Then use a timing light to check it when running together with the advance sytem operation. Hope this helps.
Rick Chisholm
02-16-2004 01:18:15
Phil check that the vacuum/ breather pipe going into the tappet cover is tight at the tappet cover with a 7/8 spanner That will affect idle. Also dont worry too much if all is not as per the book because you have an old and probably worn distributor. If a change works use it.
