can I mix gl1 and 80/90 mineral oil?
joe
02-12-2004 12:40:43
Hi, I have a TO20 (#7962), I bought 5 gallons of 80/90 mineral oil and learned here that I will need 6 so I went back for another bucket but they only had a 90 wt left so I took it. They both say GL1 mineral oil on them. Can I use the 5 gal of 80/90 and a gal of 90 without having any problems?
BTW I spent so much time on this site reading the forums and looking at pictures lately that my wife things I'm having an online affair, actually I don't think an affair would be this much fun, is that wrong?
Thanks for any info
-joe
51TO30
02-14-2004 21:39:01
 Re: can I mix gl1 and 80/90 mineral oil? in reply to joe, 02-12-2004 12:40:43
Joe,
I know the feeling, but sometimes it is more fun (don't tell the wife)it just depends on the day. I purchased the same GL1 at WalMart, they did not have it in anything small than the 5 gal.....
Lee
Mr Chapp
02-14-2004 19:45:33
Simple soloution... . Go to a different supplier and get the right oil.
Randy
02-14-2004 11:10:01
Won't hurt. It's like topping off the 10w30 in your crankcase with 30wt. The result will be a bit heavier oil. I used Shell Dentax 80w90 and it's a GL1 oil. GL1 is non EP oil. GL% is EP. Gear oils have a different viscosity scale here in North America.
Thomas
02-13-2004 14:46:46
What do you mean by 80/90 and 90 oil? In UK I would assume this to mean EP 90 (Extreme Pressure)ie gear oil. As far as I'm aware (and always do) tractor boxes use 10W30 STOU (Super Tractor Oil Universal). How do you classify oil in the US? I'd assumed it would be the same as we rate quality by API standards.
Phil(va)
02-12-2004 16:57:22
I doubt mixing 80/90 with straight 90 would be any problem at all, but I am a little confused. I have never seen GL-1 in 80/90. It has always been just 90. All the 80/90 I have found has always had additives and not been pure mineral oil or GL-1. Maybe I just haven't looked in the right places, but make sure your 80/90 is truly mineral oil or GL1. If it is, I can't see where mixing the two would be any problem.
NCtim
02-12-2004 16:18:01
"BTW I spent so much time on this site reading the forums and looking at pictures lately that my wife things I'm having an online affair, actually I don't think an affair would be this much fun, is that wrong?"
Depends on what you're doing with your tractor. :-)
