Engine Serial Numbers - timing
Phil-Australia
02-07-2004 13:21:31
Whilst researching the timing methods I have been trying to cross reference my tractor with the workshop manual. The manual refers to engine serial numbers SIE to S8995E" I have looked at my engine which is on a 1951 TED20 and it has a serial number 300508 on the block followed by a large "S" superimposed on an "M". Does any body know how this relates? I am guessing that taking the starter motor out will show me a punch mark on the flywheel and starter motor mounting pad.
Thanks
Phil
Jim W
02-07-2004 14:46:47
 Re: Engine Serial Numbers - timing in reply to Phil-Australia, 02-07-2004 13:21:31
Phil,
The number you are referring to is a casting number, not the serial number. The engine serial number is on the left side on a flat spot between the coil and the oil filler. Clean off the rust and grime and you'll find the serial number.
Below the starter motor there is a small hole in the bell housing. This aligns with a hole on the flywheel; when you can stick a piece of wire in through both holes you have found TDC.
Jim W
