oil hole in con rod
gerry
02-03-2004 15:21:18
what side of the motor should the oil hole in the con rod be on. in the book it says opp of the groove in the piston but my ne w pistons dont have the groove.
Badgerwy
02-07-2004 08:57:14
 Re: oil hole in con rod in reply to gerry, 02-03-2004 15:21:18
your new pistons shold have a arrow or a notch on them showing the direction that the piston goes.the notch or arrow goes to front of engine.the rods have numbers on thenalong with the rod caps also have numbers on them. make sure to match the numbers up. the numbers go tword the camshaft.that should help u out..... good luck
Jerry/MT
02-03-2004 21:12:36
My Ferguson Service manual says "...be very careful to have the oil spray hole in the lower end of the connecting rod, facing the opposite direction from the vertical slot in the skirt of the piston,...." . Hope this helps.
Dan S (NY)
02-03-2004 19:36:10
The I&T Shop book for my TO20 says: "Replacement rods are not marked and should be installed with the oil spray hole facing away from the camshaft side of the engine."
Dan
Rusty
02-03-2004 16:05:11
Your new pistons may have the groove on both sides. I think they are talking about the groove inside the piston.
gerry
02-03-2004 16:26:32
 Re: Re: oil hole in con rod in reply to Rusty, 02-03-2004 16:05:11
there is no groove at all not on the top or side like the old piston. the old one has a groove in the skirt.
