Rear Brakes TO-30
Ralph-Mich
02-03-2004 14:17:16
Just recently purched my to-30 and decided to check the brakes, was surprised (good condition) what a brake. But my problem is the right&left pedal assembly seems to hang down rather then in a horizontal position. I did notice that the adjustment on the clevis rod ends are quite far out. Does anyone know how long the brake rod assembly should be when connected?This might give me a starting point before installing the drums.
Ray,IN
02-03-2004 19:43:13
 Re: Rear Brakes TO-30 in reply to Ralph-Mich, 02-03-2004 14:17:16
The pull rods should be adjusted to equal length after you have the brake shoes properly adjusted. They should have just enough slack in them to prevent the shoes dragging or 1/3 main pedal depression stops the tractor, both ways are nearly equal. The L&R pedals are likely drooping down because the brass bushings in the backing plates that hold the braking shaft are worn out and need replaced. You may test this by pulling up on each pedal(vs stepping on it) to determine if each wheel brake works. New bushing are sold here(under marketplace), on other websites' and MF dealers.
