TO30 Muffler Help Needed
Ralph
02-07-2000 12:42:54
The horse club I joined has a TO30. Exhaust pipe & the obviously very non-stock "muffler" were shot and noise was incredible -- just what you need with horses around. So I took them off and went to local muffler shop; he made something up to match the old -- basically I got a new pipe with a "glass pack" near tail end. Not being a muffler guy, I figured anything that wasn't rusted through would be alot better than what we had -- wrong. It is just as loud, although it doesn't shoot fire any more and it looks better. So clearly I need to go back and get a real muffler put on. My question -- what were these originally designed with in the way of a muffler? Size, etc. Are there any constraints on what I should put on? Are these tractors deafening by design or are they "normal" noise level if I just get the right equipment. Thanks for any help you can provide.
Chip
02-08-2000 09:38:58
 Re: TO30 Muffler Help Needed in reply to Ralph, 02-07-2000 12:42:54
You should also be able to use this site's parts section to find the correct muffler.
Gene Forrer
02-07-2000 14:36:05
Most tractor supply companies have stock replacements for the T030 tractors. I got mine for only about $30.00. Probably less than the muffler shop charged you.
Gene
Jim Duncan
02-07-2000 20:08:37
 Re: Re: TO30 Muffler Help Needed in reply to Gene Forrer, 02-07-2000 14:36:05
Ralph: The muffler was shot on my TO-35 when I got it. I ordered one from Central Tractor part number 83045-123 "MF Muffler" and it cost $22.99 this was for the complete system from where it attached to the manifold right down to the tailpipe. I think that the tractor sounds fine now, don't know what the ponies think though! I think that your TO-30 would not use the same part number, and you should check with them to be sure; but I think you might need their part number 8064-123. I hope that helps, maybe others may know of a better source. Good luck! Jim
Ralph
02-09-2000 06:16:51
 Re: Re: Re: TO30 Muffler Help Needed in reply to Jim Duncan, 02-07-2000 20:08:37
Thanks for the info fellas. I did find a Massey dealer not too far away and they have an exhaust pipe/muffler for TO30 in stock for $22.55 -- I'll pick it up today. Too easy. I guess I'll kiss the $70 I spent at the muffler shop goodbye! Thanks again, Ralph
