Sherman Step Up/Step Down
Jim P
01-26-2004 15:20:28
I have a Ferguson TO30 equipped with a Sherman Step Up/Step Down Transmission. I can easily engage the Step Up and Step Down ranges but I am unable to shif tinto the conventional range. I am familiar with the pattern. When I move the lever to the Neutral position and wiggle and pull like a mule it will move out some but I am unable to then pull it into the "Std" position. What am I doing wrong? Any help would be graetly appreciated.
John, IN
01-27-2004 10:14:00
 Re: Sherman Step Up/Step Down in reply to Jim P, 01-26-2004 15:20:28
Try this link.
http://home.att.net/~jmsmith45/sherman.htm
Jim P
01-27-2004 12:31:22
 Re: Re: Sherman Step Up/Step Down in reply to John, IN, 01-27-2004 10:14:00
Thank you. I am familiar with the link provided. My problem is I am unable to shift the thing into "std". While it may seem like a simplistic request, can someone decribe the proper method of shifting this trans? I can drive almost anything but can't hit the pattern on this trans!!! I can easily shift between Step Up and Step Down but cannot get he lever to move out and then down into the "std" position. Could something be worn? I say this because the trans will not stay in Step Up for long (while moving) before falling into Neutral I believe by the shear weight of the shift lever! Could this be clutch related (i.e out of adjustment or worn)? Again, any help would be appreciated
