ETSHOBBY
01-22-2004 22:22:55
Well been really cold but the to30 always started great hardly ever have to chock her.I have fully restored and rebuilt everything new & used for a year now . Parked her in the garage last week with no problems, went to start her the next day didnt want to start so I chocked & flooded real bad, Clean everthing back up burned off the cylinders, just got done with new coil, plugs, condensor, points ,distributer cap, rotor ,set everything gaps ,triple checked them all,great spark off coil. jumps 3/4 inch no problem, everything is 12 volts also, rotor turns ,timing ok checked valves opening closing ok , distributor turns ok have checked gear,made sure rotor is contacting at top of distribtor cap inside carbon, also making correct contact to spark plug contacts inside cap, plugs fire have removed and watched them spark seemed a little weaker but bright blue spark ,Great compression,piston comes up number one timing is ok checked flywheel mark and distributor pointed at one.Plug wires firing order ok I have been through everything 5 or six times a day for about 5 days now.Tried starting fluid nothing. Has something probably to do with the cold but I dont know what would have changed has started great last winter and up until now. I am not unexperienced but this time am without a nickel to make start? all suggestion welcome. thanks gene
