Regulator in Delco 10si Alternator
Jim W
01-21-2004 17:53:58
Looking back in the archives I found the following information:
"It sounds like your delco has the "one wire regulator" in it, with this regulator you only need to hook up the battery wire on the rear of housing, it does not need the two spade terminals on the side hooked up even though they are there, this type of regulator needs to be spun up fairly fast before it will start to charge, after it starts to charge it will continue to charge at low rpms, there is 2 different ones of these regulators the good one does not need real high rpms to energize system and a good electrical shop can get you the correct one, but because you went to the work to hook up a light you should be able to just get a replacement regulator (non self energizining) and install it and it should charge at very low rpms, i can provide #'s if you need, good luck! "
He goes on to tell him the regulator number is Blue Streak VR-111.
So I have three questions about that:
First, I already have a 10si that I have put on an old car I am restoring, but the engine is not back in the car so I haven't tried it out. How can I tell if it has the one-wire or three wire regulator? It does have the P1 and P2 tabs.
Second, I am thinking of using a 10si on a 20-85 I am restoring, so I want it to start charging at low speed. I guess with the VR-111 regulator you would hook up +ve from the ignition switch through a diode to P1, but do you hook P2 directly to the Battery terminal on the alternator?
Third, if you want a warning light, where would it go?
Thanks,
Jim
Bob
01-23-2004 07:38:47
 Re: Regulator in Delco 10si Alternator in reply to Jim W, 01-21-2004 17:53:58
Here's a site with detailed information on 1 and three wire alternator conversions, etc.. It's hot-rod oriented, but much of it applies to 12 Volt tractor conversions.
Link
Ford Alternator
01-22-2004 14:24:24
Found this in my archives:
6 to 12-Volt Conversion of Ford 2000 and 4000 4-Cylinder Ford Tractors
by Tommy Duvall After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition.
By writing this step-by-step procedure of what I have done, I hope to benefit others who wish to convert their x01 series or early 2000/4000 to 12 volt, so here goes... The Parts: 1. Delco 10si Alternator. I used the 1 wire Marine version, but the 3 wire version is not much more difficult to wire. I got mine at the local alternator shop for around $50, but this was expensive. The new alternator I got had a 3/8� pulley, where the generator had a �� pulley. This makes the belt ride kinda high, but still works well so far. I am going to leave it for now, but there are �� pulley available for the 10si. (* See Below - I believe the one in the Genesee Kit has the �� already on it) 2. A bottom alternator mounting bracket of some kind. This scared me the most, as I am not very good at fabricating things (that work anyway) (* See Below) 3. Wires & Terminals: � a. 1 - 25' roll of 14 gauge wire � b. 1 - small roll of 10 gauge wire (You only need about 3 feet) � c. 1 small box (10 or so) of small 14-16 gauge ring terminals � d. 1 small box of large 14-16 gauge ring terminals � e. 1 small box (10 or so) of small 10-12 gauge ring terminals � f. 1 small box of large 10-12 gauge ring terminals � g. Wire Cutter/Crimpers 4. A 3 ohm, 12 volt coil, with internal resistor. This was EXPENSIVE for a coil - Paid over $40! (* See Below) Note: The primary resistance of coils from different manufacturers varies. So long as the coil is not a high output type, or intended only for use with electronic ignitions or racing, the primary resistance of the coil should fall within an acceptable range. Most of the high output coils have a lower primary resistance, and can go through a set of points in no time. And for that same reason, having a standard type coil WITH an internal resistor is very important. 5. A Voltmeter. About $20-$30 at the parts store. (* See Below) 6. (not required, but smart) A 12 volt solenoid, which is activated by grounding the "S" terminal with the starter button. Most automotive solenoids WON'T work, as they require "+" flow to one post, and the other bypasses the external ballast resistor to deliver more power to the coil to aid in starting. These are $15 at most tractor repair shops, or Ford/NH dealers. Be sure to tell them you want 12 volt solenoid - not 6. Also you can use a Napa ST-56, which has only the �S� terminal. It is 12 volt, and can be wired just like the original Ford solenoid, except you don�t need the wire from the key switch to the �I� terminal, since it does not have one. 7. A good 12 volt battery that fits in the battery box. * NOTE: Genesee Products sells a conversion kit which includes all the above, except the solenoid and battery. Their kit sells for MUCH less than I paid for the parts I bought various places, and will save time as well. If I were doing another conversion, I would just let them ship me the stuff & begin, instead of running all over town and explaining what you are doing and what you need. Removing Stuff: 1. Remove the old battery completely. Now might be a good time to replace or at least clean and patch up the battery box. 2. Remove the air cleaner and tubing to the carb. I also took this opportunity to soak the cleaner element in solvent, and later rinse out good. Of course, change the air filter oil and clean the cup before reassembling. 3. Unscrew and detatach the wires from the existing 6 volt generator. 4. Detach the wire from the coil on the opposite side of the tractor and pull the wire from the coil back around to the generator side of the tractor, and together with the wires to the generator (they are taped together) and pull back to the solenoid. 5. Remove the wire from the coil to the distributor. 6. Pull the wires from the two front posts on the solenoid. 7. Remove the key switch and unattach the 2 wires attached to it. 8. Remove the 2 screws holding the voltage regulator under the dash 9. Remove the connections to the voltage regulator and remove the regulator. The 10si alternator is internally regulated, so you won't need the voltage regulator any more, but keep it in case you ever want to restore 6 volts. 10. Unconnect the wire on the starter button and pull it back up under the dash. 11. Remove the existing wiring, except the headlight/rear light wiring. This is separate to the ignition and starter wiring, and only attaches to the voltage regulator to get power. It has a separate switch and in-line fuse, and need not be replaced, given the wires still look good. HOWEVER DO replace the bulbs or they will fry pretty quick getting 12 volts! 12. Unbolt the generator from the mount, leaving the existing mount in place. It will be used with the Genesee brackets to mount the new alternator. Keep the generator in case you may want to restore it back to original 6 volt someday. 13. Remove the 6 volt coil. Now, the reassembly: 1. Mount the new mounting brackets from Genesee by bolting them to the existing bracket. This is hard to explain, but not hard to do. You will see when you get the brackets in-hand. Be sure to get the alternator lined up with the fan and crankshaft pulleys. If you choose to make a bracket, make sure it is sturdy enough to hold the alternator. Now, mount the alternator. 2. You will need a new, longer belt, since the alternator is farther away than the old generator was. I took my old belt to the auto parts store and got them to let me take 3 belts: one that is 1/2" longer than mine, one that is 1" longer than mine, and one that is 1 1/2" longer than mine. The one that is 1" longer worked for me, and I returned the others. I wish I had saved the sleeve to give you the Gates number, but I discarded it. (learned something) 3. The top adjustment bracket can be used as is. I loosened the bolt holding it to the block so I could get the alternator bottom brackets adjusted properly. Now, place a few flat washers between the top bracket and the alternator to get the positioning right. Notice the bolt will now enter from the back of the alternator mounting ear, thru the bracket and the washers. 4. If you got a new solenoid, remove the old one and mount the new one now. 5. Mount with the new coil. I mounted mine with the "-" post towards the distributor, but since we will be rewiring, it really doesn't matter. 6. I mounted the voltmeter in the place of the fuel gauge on mine, since my fuel gauge does not work, and isn't missed much. My fuel gauge now is a clean 28" piece of bamboo I keep in the shed, and dip into the tank to see how far up the bamboo gets wetted. I'll fix *someday*. Please be aware, however, that 12 volts will also fry your 6 volt fuel gauge. (Something about �frying� and �fuel� just don�t go together very well) It will either need to be replaced, or resistors added to its circuit to reduce the voltage. I haven�t checked, but a dollar says the fuel gauge from the diesel versions of these will work! Now the wiring: 1. Crimp 2 small ring terminals onto each end of a 6" piece of wire, and run from the "-" side of the coil to the distributor. 2. Run a wire from the "+" side of the coil back around the tractor to the switched side of the key switch (i.e. the side that only gets power when the key switch is on) Crimp terminals on each end to attach. 3. Run a 10 gauge wire from the "BAT" (and only terminal on the 1 wire version) terminal to the side post on the solenoid where the battery connects. This will require a small 10-12 gauge ring on one end, and a large 10-12 gauge ring on the other end. 10 gauge wire is required here because the alternator can really put out some amps if the battery gets low, and the alternator needs to recharge it. 4. Run a wire from the solenoid post where the battery cable attaches to the "hot" side of the key switch. This too will require a small ring on one end, and a large ring on the other end. 5. Run a wire from the switched side of the key switch to the "I" terminal on the front of the solenoid. Attach using small ring terminals. 6. Run a wire from the pushbutton starter on the top of the transmission to the "S" terminal on the front of the solenoid. Attach using small ring terminals. 7. Run a wire from the switched side of the key switch to the "+" side of the voltmeter. Then run a wire from the "-" side of the voltmeter to the "-" battery post, frame, sheet metal, or other suitable ground. Attach using suitable rings. 8. This is optional, but I put most of my wiring in automotive conduit, available at most auto parts stores. This shields the wires from things like engine heat and stray limbs, bushes, etc while working. Now the battery: 1. Place a 12 volt battery in the battery box, with the positive ("+") side towards the inside. Notice this is opposite from the way the 6 volt battery way in the box. Take the old 6 volt to the battery store with you so you can both match the physical size, and dispose of the old battery properly. 6 volt batteries are still made and widely available. 2. Hook the POSITIVE ("+") side of the battery to the solenoid, and the "-" side to the ground. 3. BE SURE the key switch is in the "off" position, and attach the negative ("-") post of the battery to the ground wire. (NOTE: BE SURE you have the "-" side of the battery grounded. Get it backwards and your alternator has had a bad day) Now check it out: 1. With a small DC test light, hook the light ground clip to the "-" side of the battery. Turn the switch on and observe the voltmeter mounted in the dash - It should rise to 12 volts (or close to it). � a. Touch the battery side of the solenoid with the test light - the light should come on. � b. Touch the "I" post on the front of the solenoid with the test light - the light should come on. � c. Touch the "S" post on the front of the solenoid with the test light - the light should come on. � d. Touch the "+" post on the coil with the test light - the light should come on. 2. If all the above check out, hit the starter button. It should spin over MUCH faster than with the 6 volt system, and will probably crank almost immediately. (Be aware that now you are sending 12 volts to a starter designed for 6 volts. The starter could be damaged by excessive cranking, so if she doesn�t start pretty quickly, let the starter rest between attempts. I personally won�t let the starter run over about 5 to 7 seconds at a pop.) The voltmeter should read about 13.5 to 14.5 volts with the engine running. If it stays at 12, rev up the engine. Mine took this to begin charging. Don't forget to put the air cleaner back on. Lastly: Replace all the light bulbs with 12 volt bulbs. My dealer looked up the bulbs for the diesel version of mine, but said they were the same as most of the "Blue Thousand Series" until well up into the 80's. I had an aftermarket rear fender light on mine which had no replacement bulb, but I only paid $10 for it at a flea market. I will get another 12 volt light at the same flea market later on. The light bulbs don�t have to come from a tractor dealer, however. Any auto parts counter man(excuse me, person) who is willing to spend two minutes doing it, will be able to come up with 12 volt replacements of the same types and candlepower. That was it on mine! I have just completed this conversion, and will see this spring when it is time to hookup the ole 2-bottom or brush-hog, but I feel that, given how much better she cranks, my starting problems are well diminished. Besides, I can now boost her off with my pickup or other tractor, without worrying about a battery explosion. One other thing I am going to do soon is install a Genesee Electronic Ignition System on this ole girl, so points & condenser will no longer be a concern. Lastly, let me say how helpful Andy at Genesee Products has been! I messed up and didn't get their kit, but my advice to anyone converting most any tractor to 12 volts is to give them a call. They can and will save you a lot of time and money - Not to mention you won't have to "hide and cuss" while trying to make a bracket from your wife and kids. They have already done that for you. Not only is their merchandise first rate and very reasonable, but their expert advice was very helpful for a first-timer like me! (And no, I don't have stock in Genesee - They really did help me. Honest!) Lee..... ...tell the ignoramius's that yer Delco 10-SI is from a 1967 Chevy pick'em-up. 'course they could have researched the Delco part number if'n they were sharper than a tack-head. Some ill-informed shadetree mechanics think that by just using the BIG rear battery stud and ignoring the 2-side terminals, they've magically created that deceptively desireable 12 volt 1-wire alternator. NOT SO. A true 1-wire Delco alternator has the internal solid state gutts changed out and the 2-stake-on's covered witha molded plug so no-one is tempted to use them. One-wire alternators are also popular with inboard/outboard boating types and also hot-rod types. I'm not a 1-wire alternator advocate 'cuz ya haffta jazz yer cold engine to about 1800 rpms before it'll start charging on its resisdual magnitizm. Once it starts charging, it'll charge at 500 rpms like the 3-wire alternator does with the GM idiot lite in the "P-1" (excite) side terminal does from the gittgo. The 2nd side terminal, "P-2" (external volts sense) should be hardwired to the BIG battery stud on the back of the alternator. It is what tells the internal voltage regulator how much to charge the battery..... .....respectfully, Dell..... a 12 volt advocate for the right reasons
marlowe
01-21-2004 18:48:25
a one wire alt. has to be made as a one wire. on a one wire you will only have one post and p1 anp2 are covered
Jim W
01-22-2004 05:29:32
 Re: Re: Regulator in Delco 10si Alternator in reply to marlowe, 01-21-2004 18:48:25
Do you mean the tabs for P1 and P2 are there but have a cover over them, or do you mean there is a cover and the tabs aren't there at all?
Jim
Chris Brown
01-23-2004 18:03:27
 Re: Re: Re: Regulator in Delco 10si Alternator in reply to Jim W, 01-22-2004 05:29:32
The one wire alt I bought from oriellys had a plastic plug over the two prongs covering them. But they were there.
marlowe
01-22-2004 11:17:31
mine are gone but that is the type of kit i use when i make them up
