Ignition Switch
Paul F B
01-17-2004 11:12:34
Having a little trouble finding the proper ignition switch for my TEA. Does anyone know how the TO switch matches up or any other suggestions?
Jerry/MT
01-17-2004 14:07:52
 Re: Ignition Switch in reply to Paul F B, 01-17-2004 11:12:34
Gosh Paul, I would think just about any ignition switch would work. Is there something special about the TEA ignition sytem? It only closes the ignition circuit I believe. Try the parts folks on the left, NAPA, or an auto parts store.
Jerry/MT
01-17-2004 14:10:11
 Re: Re: Ignition Switch in reply to Jerry/MT, 01-17-2004 14:07:52
Another thought. You might try bareco.com. They handle parts for British tractors.
Tractorfix
01-17-2004 16:11:55
 Re: Re: Re: Ignition Switch in reply to Jerry/MT, 01-17-2004 14:10:11
If you have to have a Lucas switch, there are several internet vendors hawking them. Another thing you may not know is that they all use the same key so any Fergy ign. sw. from the boneyard will work. You can also get it from a Dexta. If it is just the key you need, I am pretty sure the same vendors can supply them too.
Paul F B
01-18-2004 12:55:24
 Re: Re: Re: Re: Ignition Switch in reply to Tractorfix, 01-17-2004 16:11:55
Tractorfix; Could you help me find the internet vendors? Thanks, Paul
Paul F B
01-17-2004 20:46:36
Tractorfix, I need the whole switch, I didn't lose the key. Local Massey dealer sent me a switch that was just to large. My guess woud be that the 8N switch would fit. I also plan to check NAPA as Jerry suggested. I didn't see anything on the Bareco site. Paul
Phil(va)
01-23-2004 14:15:52
 Re: Re: Re: Re: Re: Ignition Switch in reply to Paul F B, 01-17-2004 20:46:36
The Ferguson TO-35 switch, available at MF dealers and some other places, like Stevens in LA I believe, will fit the hole and do the job perfectly. It includes notches for the lights too, which you may or may not use. Also uses the universal MF key as others mentioned.
tractorfix
01-18-2004 19:38:07
Check out Dunlop Hydraulics. They have a web site any search engine can find. The part # is 39119. You have to go into the Dexta parts list to find it .
Ray,IN
01-18-2004 19:40:41
 Re: Re: Re: Re: Re: Re: Ignition Switch in reply to tractorfix, 01-18-2004 19:38:07
davistractor.com or ----- -- sell the original switch.
tractorfix
01-19-2004 02:31:13
 Re: Re: Re: Re: Re: Re: Re: Ignition Switch in reply to Ray,IN, 01-18-2004 19:40:41
Mine has a toggle switch
Paul F B
01-26-2004 06:28:43
 Re: Re: Re: Re: Re: Re: Re: Re: Ignition Switch in reply to tractorfix, 01-19-2004 02:31:13
Just to let you fellows know, and to close off this topic, I got a switch from a Case dealer that fits pretty well. Thanks for all your help. Paul F B
