Electrical tach hook-up
J.B.in N.C.
01-14-2004 07:10:51
My to35 has an alternator and a coil with internal resistor.I have a dat-com tach with hour meter to install.The directions are unclear to me as I am electrically challenged.Anyone have suggestions? THANKS.
Cosmo
01-14-2004 12:12:05
 Re: Electrical tach hook-up in reply to J.B.in N.C., 01-14-2004 07:10:51
I think that is the kind I installed on my 35 a couple of years ago. I am currently goofing off at work but when I get home I'll check to see what I have and may be able to help. Most likely I threw away the paper work though. The hardest part for me was getting these old big knuckles in such tight quarters.
Mickey Cook
01-21-2004 03:00:50
 Re: Re: Electrical tach hook-up in reply to Cosmo, 01-14-2004 12:12:05
I would love to know more about the tach you are installing. Where did you get it? How can I order one?
J.B.inNC
01-21-2004 15:49:55
 Re: Re: Re: Electrical tach hook-up in reply to Mickey Cook, 01-21-2004 03:00:50
Mickey,I got mine from dennys carb shop.It is the same size as the original on the to35.The cost is about 120.00 with hourmeter and 80.00 without.You could get the same tach from other sources a bit cheaper[it is a dat-com],or so I was told after I GOT ONE.
