torquing head bolts with crow foot
jim in ky
01-12-2004 20:46:40
Can someone please tell me how many pounds of torque to use when torquing the hard to get to head bolts with the crowfoot wrench i know the others is 75pds. Thank you very much for your help. z129 jim
Jerry/MT
01-13-2004 15:34:14
 Re: torquing head bolts with crow foot in reply to jim in ky, 01-12-2004 20:46:40
Jim,
Adding a crow foot to a torque wrench increases the applied torque so you have to reduce the indicated torque to get the correct torque. If the distance between the centerline of the torquewrench drive and the centerline of the head stud is delta and the length of the torquewrench from the from the end to the centerline of the the drive is L, then True Torque/Indicated Torque = (L+delta)/L. So if L is 15 inches and delta is 1 inch and the indicated torque is 75 ft-lbs, True Torque is
75 x (15+1)/15 = 80 ft lbs. to get to 75 ft lbs with this confifuration, you would pull 70.3 indicated ft-lbs (75 x 15/16). Hope this helps.
