to30 temp gauge
fireland
01-12-2004 02:21:29
Water Temp gauge on 53 TO30 stll works butis hard to read. Bought a universal type replacement but can't install it. The bulb on the end is too long to fit where the old one was installed. Do I need to buy a different gauge or can I just cut the end of the bulb off to make it fit? The old one was attached to the fitting on the block for the top radiator hose.
MikeOk
01-12-2004 18:50:35
 Re: to30 temp gauge in reply to fireland, 01-12-2004 02:21:29
I just bought a water temp gage for my 53' TO30. The package has a note: "The sensor line is under pressure and filled with ether". Mine came with 2 brass fittings that are screwed together to shorten the length inside the block. I won't be able to install it tell this weekend but if you'd like to know how it goes leave me a note here.
Mike
fireland
01-12-2004 21:15:36
 Re: Re: to30 temp gauge in reply to MikeOk, 01-12-2004 18:50:35
Looks like I'm going shopping. Will try the dealer(40 miles away)or try to rig some kind of extension with pipe fittings.
Jerry/MT
01-12-2004 11:59:12
Don't cut the bulb, the fluid will leak out. Try your MF dealer and see if he can get you the right one. You might try to see if you can put in a pipe bushing that will extend out and allow the longer bulb to fit. Hope this helps.
paul in ms
01-14-2004 16:10:58
 Re: Re: to30 temp gauge in reply to Jerry/MT, 01-12-2004 11:59:12
when i installed a temp. gauge on my to-20 i used one of the supplied fittings to screw in first then screwed the bulb in. i had to tap out the hole slightly.
