Need help - TO-35 runs too good - 3000 rpm
Kevin KS
01-09-2004 06:23:49
I just did a rebuild on a '55 MF TO-35. New Pistons, sleeves, head and all. Purrs like a kitten at idle of 380 to 400 r's. Grab the throttle and watch out! The first try it hit 3200 rpm and after arguing with all of the adjustments that I can adjust, the slowest high end rpm that I can get is 2850. The I.T. book says 2200 rpm. I removed the timing cover to see if everything with the balls and such was working freely thinking that I may have used too much assembly lube and it all works real free. So, put it back together, clocked the tab on the govenor at 8 o'clock, detached the rods (per the book) and adjusted it again like the book said. Bam! 3200 again. How do I keep this brand new engine from sticking a rod through the side of the block? When running the throttle by hand, and holding the gov. rod, there is a very slight pull back as r's increase, but not near enough to pull the rather large spring back. Any help would be appreciated!
Thank you Kevin
Gregg/Ohio
01-09-2004 19:29:22
 Re: Need help - TO-35 runs too good - 3000 rpm in reply to Kevin KS, 01-09-2004 06:23:49
Be careful on letting your Z134 Cont. run up that high.(even for a short while) I know the Tractor Pullers run that high or higher on the old Fergusons, but I was told that they (Z134's) dont like much more than 2500 RPM because of that long stroke.
Kevin KS
01-11-2004 16:52:46
 Re: Re: Need help - TO-35 runs too good - 3000 rpm in reply to Gregg/Ohio, 01-09-2004 19:29:22
Thanks Gregg.
I am trying to get the little z134 settled down but after several hours, still no luck. I have just about worn out the "U" bolt on the shaft. I think that I am going to try to replace the spring. Someone could have put one on it from a larger engine. Hmmm, wonder if one off a Briggs and Stratton would slow it down. Just kidding... Still would like any other knowledge that could help.
