need source and advice on TO-20 generator
George in NW Mi
01-08-2004 07:56:20
My generator on my TO 20 is not working, electrical shop says the brushes look new but it only puts out a couple of amps...tested with and without the new regulator.
Should I get a new or used one, or should I let the shop try replacing the armature?
I tried the sources linked to this page but did not find one...can anyone recommend a source?
Ray,IN
01-08-2004 23:33:51
 Re: need source and advice on TO-20 generator in reply to George in NW Michigan, 01-08-2004 07:56:20
Any reputable generator repair shop should rebuild your generator for less than the cost of a rebuilt one on the net($140). Waltstractor.com and davistractor.com both list rebuilts if your local rebuild shop appears hesitant.
Duner Wi
01-08-2004 18:21:32
Your shop should know exactly what parts need replacing. If they don't know, find another shop.
I pretty much always would have the old original repaired.
01-09-2004 06:54:15
 Re: Re: need source and advice on TO-20 generator in reply to Duner Wi, 01-08-2004 18:21:32
I actually did take it to the electrical shop that my local MF dealer recommended. The guy there told me the brushes looked new and it would put out a couple of amps. He asked me to bring in the regulator so he could try them together. He was unable to get them to work right.
He trued up the armature with no improvement. He said he could replace the armature but the cost would be nearly as high as getting a rebuilt one. So that is where I am, cost from local MF dealer is $210. I did check with mail order places mentioned, and they have core charge and shipping costs, which get you much closer to the MF price.
I am leaning towards going with MF dealer....at least if this doesn't work I could return it.
Duner Wi
01-09-2004 17:12:06
 Re: Re: Re: need source and advice on TO-20 genera in reply to George in NW Michigan, 01-09-2004 06:54:15
Armatures are normally tested for shot circut on a growler. I would think every shop would have one. Your elec. shop should be able to test for exactly the defective part/parts. Sorry I can not be of more help. Good luck!
marlowe
01-08-2004 09:50:58
save your self some money and a lot of head ackes and go with a 1 wire delco alt. 6or 12 volt - or + ground about $60.00 you will have to make a new bracket to hold it but not hard i make them for lots of people
marlowe
01-08-2004 09:52:55
 Re: Re: need source and advice on TO-20 generator in reply to marlowe, 01-08-2004 09:50:58
you in the UP or lower mich. i'm in wi.
01-08-2004 11:23:02
 Re: Re: Re: need source and advice on TO-20 genera in reply to marlowe, 01-08-2004 09:52:55
I am located on the Leelanau peninsula, about 20 north of Traverse City, lower peninsula. I have always wanted to take my boat over to Wisconsin but the lake is just to dangerous for me.
I thought about an alternator but I want to keep it as original as possible.
George
marlowe
01-08-2004 13:05:11
 Re: Re: Re: Re: need source and advice on TO-20 ge in reply to George in NW Michigan, 01-08-2004 11:23:02
hay thats cool just tought i would tell you about the alt. i bet your in snow country we don't have sh-t on this side of the pond
kenMi
01-16-2004 09:29:47
 Re: Re: Re: Re: Re: need source and advice on TO-2 in reply to marlowe, 01-08-2004 13:05:11
If this conversation is still going on: I am having trouble with my regulator on a TEA 20-85, 1952, built overseas. (I have had my generator tested OK)I may be able to buy a new regulator,... but expensive. There is probably a close match,... BUT. I don't care about detailed original,... if I spend $ on a 6v system, experience says I'll obviously struggle with it for years. Why not do a 12V conversion? Can you tell me what is involved? Same Starter, Starter switch. New regulator, alternator. I am planning on fully rewiring anyways. What from the 6V system will hold up to 12V? Thank You!
