cold running problem and charging problem
George in NW Mi
01-04-2004 14:55:18
My TO-20 starts easily enough but needs choke to run for awhile. That sounds normal but it never really gets warm enough to run right. It just feels like the mixture is too lean and it will just stop if any sort of load is put on it.
Is there an adjustment, idle mixture perhaps that could improve this?
Second question: It was not charging and I took the generator to an auto-electric shop. The guy said he tested it and it did put out about 6 amps. He asked me to bring in the regulator and test the generator with the regulator. Under these conditions, the generator did not charge. The regulator is a new mechanical-type that I put on hoping to solve the problem myself.
What could cause this result?
Ray,IN
01-04-2004 18:52:38
 Re: cold running problem and charging problem in reply to George in NW Michigan, 01-04-2004 14:55:18
The job of an engine thermostat is to obtain and maintain the best operating temperature for efficient engine operation. The lack of a properly operating thermostat will cause your complaints about cold weather running. New thermostats are available from Carquest, NAPA, and your local MF dealer, all you need is your tractor ID. The charging system needs to be matched for optimum charging. This means the regulator and generator should be set at the same time. Charging system output is 16-19 amps at normal operating temperature. This is a normal circumstance for Harry Ferguson generator systems. I would revisit the repair shop, buy a new regulator from them and have the charging system matched, you'll be glad you did in the long run.
Mr Chapp
01-07-2004 18:13:00
 Re: Re: cold running problem and charging problem in reply to Ray,IN, 01-04-2004 18:52:38
Agree with ray 100%. If the shop says the regulator / generator is the problem, let them prove it. Let me know how it turns out, as I have my doubts...good luck, have fun.
