POSITIVE GROUND OR NEGATIVE
DAN YORK
01-03-2004 11:51:00
JUST PICKED UP A TO 30 AT AUCTION NOT RUNNING
WHEN I INSTALL THE NEW BATTERY IS IT + OR - TO GROUND????
SER 116491 UNDER STEARING WHEEL
Z129 358938 ON ENGINE BLOCK
Phil(va)
01-03-2004 20:38:37
 Re: POSITIVE GROUND OR NEGATIVE in reply to DAN YORK, 01-03-2004 11:51:00
As the others said, it was originally 6 v, + gnd. However, if it has an alternator on it, you might assume it has been converted to 12 v and in that case it would be - gnd.
marlowe
01-04-2004 07:38:49
 Re: Re: POSITIVE GROUND OR NEGATIVE in reply to Phil(va), 01-03-2004 20:38:37
phil[va] not true i have a 6volt alt. that was made for + ground you can get them eather way
Phil(va)
01-05-2004 10:02:54
 Re: Re: Re: POSITIVE GROUND OR NEGATIVE in reply to marlowe, 01-04-2004 07:38:49
OK, thanks. I have never seen or heard of a six volt positive ground alternator. Learn something every day I guess. Did yours come from a factory, like Delco, etc.? Or was it made up specially?
marlowe
01-05-2004 11:33:52
 Re: Re: Re: Re: POSITIVE GROUND OR NEGATIVE in reply to Phil(va), 01-05-2004 10:02:54
the shop that dose my alts. and starters makes them up for my 55.00 with a delco core
Mr Chapp
01-07-2004 18:25:03
 Re: Re: Re: Re: Re: POSITIVE GROUND OR NEGATIVE in reply to marlowe, 01-05-2004 11:33:52
Cant quite imagine why anyone would want a 6v pos ground alternator. If a complete restoration a 6v pos ground generator maybe. Engineer friends, please reply... I thought the most electrically efficient was 12 volt, neg. ground. This comes from one who has lived with MG automobiles for many years.
John
01-03-2004 14:39:36
12v systems started on TO-35 at serial number 161250 and was negative ground. Your tractor, from 1953 is positive ground 6v originally.
marlowe
01-03-2004 13:33:40
from the factory they are +ground 6 v
