new to me - TO 30 / TO 35
Doc
12-22-2003 07:32:01
From doing a little searching I am now really confused. I just purchased a Ferguson TO 30 or TO 35, I'm not sure. A cast # just below the sterring column reads TO-3551. The data plate above the sterring just gives all the patents and the Ser.# as 103822.
The data plate on the engine gives the follwing: Motor # Z129-345013 Continental Motors Corp. I guess what I need to know is "what do I have and when was it made"???? Thanks for any help
Doc
toolman
12-22-2003 11:52:06
 Re: new to me - TO 30 / TO 35 in reply to Doc, 12-22-2003 07:32:01
going by the serial # doc , looks like a 53 to 30.
walterwilliam
12-22-2003 08:21:36
Look to the left under Research and Info, Serial Numbers. It looks to me like it is a TO30 and the serial number will give you the year.
Charles
12-22-2003 09:09:42
 Re: Re: new to me - TO 30 / TO 35 in reply to walterwilliam, 12-22-2003 08:21:36
I have a TO 30/35 Furguson, I don't know which. The plate on the dash under the steering wheel is worn off. Is there any other identification on the tractor motor or some where?
Thanks Charles
Phil(va)
12-22-2003 15:09:13
 Re: Re: Re: new to me - TO 30 / TO 35 in reply to Charles, 12-22-2003 09:09:42
Hey Charles, quick guide for the "TO" tractors using engine numbers: Z120 = TO20; Z129 = TO30; Z134 = TO35. (The Z134 was also used on the F40, but it's hard to mistake that with the others.) As Alvin says, The 35 (and 40) have a high/low tranny with an extra shift lever for total of six gears forward. The others have one lever and four forward speeds. Hope that helps.
walterwilliam
12-22-2003 08:20:04
Look to the left under Research and Info, Serial Njmbers. It looks to me like it is a TO30 and the serial number will give you the year.
Alvin n Ms.
12-22-2003 08:41:52
 Re: Re: new to me - TO 30 / TO 35 in reply to walterwilliam, 12-22-2003 08:20:04
Forget, the numbers. If you have two gear shift levers, then you have a 35. The TO30 only had 4 foward, one reverse speed. alvinnms
john(UK)
12-23-2003 12:34:49
 Re: Re: Re: new to me - TO 30 / TO 35 in reply to Alvin n Ms., 12-22-2003 08:41:52
Its a TO30...1952
