Gas in the oil
J.B. in NC
12-20-2003 04:03:18
My to35 has developed an interesting malady.Perhaps some of you folks out there have seen this before.The engine runs fine for about 10 hours.The oil pressure then starts dropping.What I have found is the oil is diluted with gas. At the same time number 1 cly.gets an oily coat on the plug.DRAINING THE OIL and putting in fresh oil cures the problem until about 10 hours of run time.ALSO,cyl.1 smokes a little and emits an oily residue from the juncture of the block and exhaust manifold.My thoughts are that a valve is stuck or damaged.BEFORE ordering a kit,I WOULD APPRECIATE any help on this matter.
Mr Chapp
12-21-2003 07:44:24
 Re: Gas in the oil in reply to J.B. in NC, 12-20-2003 04:03:18
I personally would do as suggested, check compression first. I suspect that #1 is the weaker cylinder, however, a carburettor rebuild would be my second step. I suspect flooding through #1 cyl. when shut off. Good luck, have fun.
Jerry/MT
12-20-2003 21:12:17
Make sure the carb float setting and the needle valve in the carb are set and working properly.
Kelvin
12-20-2003 17:40:41
Saw a Ford Jubliee do that-carb would leak enough when the engine was shut off to trickle fuel into the cylinders where it would leak past the rings. That tractor required carb kit and a ring job.
capt kirk
12-20-2003 15:56:54
do a compression test first to determine the mechanical condition. i dont think a cylinder missing would dump enough gas to dilute oil in 10 hours. check your fuel pump for a bad diaphram. good luck and let us know
Jim W
12-20-2003 06:01:10
Could it be as easy as no spark on #1 cylinder, hence fuel not burning and going by the rings?
(always hopeful) Jim W
john(UK)
12-20-2003 10:25:10
 Re: Re: Gas in the oil in reply to Jim W, 12-20-2003 06:01:10
Not having seen a MF35 gas model I dont know the engine spec...but I know we used to get problems with the fuel pump diaphragm cracking and leaking fuel into the oil pan via the camshaft gallery on the diesel models....That is if there is such a thing on your tractor.If its a Perkins gas engine it may have a pump if its Continental ..I dont know the spec.
john(UK)
12-20-2003 10:24:35
Not having seen a MF35 gas model I dont know the engine spec...but I know we used to get problems with the fuel pump diaphragm cracking and leaking fuel into the oil pan via the camshaft gallery on the diesel models....That is if there is such a thing on your tractor.If its a Perkins gas engine it will have a pump if its Continental ..I dont know the spec.
J.B.inNC
12-28-2003 16:06:31
 Re: Re: Re: Gas in the oil in reply to john(UK), 12-20-2003 10:24:35
Appreciate all your responses.Turns out my distributor had moved a bit due to a jury-rigged retention bolt,causing the malfunctions I posted earlier.I love this board.
