nothing but rust
John, IN
12-15-2003 17:14:11
I have had my TO20 for going on 3 years now and I am always learning something new about it. Like just the other day I have been having to jump start it now that it is cold. It has always turned over slow but more so in the winter. Even with a jump it seamed to turn over very slow. By the way it is a 12 volt system. Checked all the conections and found none to be loose. I knew that something was up, just out of dumb luck I put my hand on the starter and it was hot by where the 12+ hooks to. Give the wire a good hard yank and low and behold it was loose. Rust was what was holding it tight. Cleaned tighten and it now turns over like a top. Sometimes just tightening up a conection is not good enought. You should take it off clean and retighten then.
James, UK
12-16-2003 03:28:05
 Re: nothing but rust in reply to John, IN, 12-15-2003 17:14:11
Remember the mantra, and repeat as often as needed . . . .
"Clean, bright, and tight, clean, bright, and tight . . . . ."
Mr Chapp
12-15-2003 17:34:59
Good for you!!! So many places to look for a good connection, so little time to do it. Probably the best thing to do is take the connections apart and clean them with 400 grit emry cloth or the equivelent. A little dilectric grease never hurt anything. MERRY CHRISTMAS!!! And have fun.
