TE20 Shear Coupler
Phil Hancock
12-12-2003 12:53:23
Thanks to those who responded to my earlier post. How difficult is it to change the shear coupler on a te20? Do I need to source a workshop manual?
Thanks
Phil
john(UK)
12-14-2003 05:46:04
 Re: TE20 Shear Coupler in reply to Phil Hancock, 12-12-2003 12:53:23
Sounds like you have a broken axle shaft. if you put the tractor in gear and watch the rear wheels you very often see one wobbling, that is the side with the broken shaft. If it was the diff assy usually it will drive but make a loud noise.
marlowe
12-12-2003 15:34:56
one thing to do first is pull the oil fill pulg next to the shift leaver start tractor and put it in gear use a light and look in hole for gear movement if they move then it's the coupler if no movement the you have to look for something differnt
marlowe
12-12-2003 15:29:11
first you have to drain the trans and rear end oil. then pull side covers [the round ones] and look in side at the long fork that goes to the hyd. pump. pull fork apart a little to get it loose from the pump wish bone. pull bolts on cover and lift off slow if any resistance is filt you might not have the fork unhooked. with cover off look at the shaft to the top and you should see the brake in the tube [there is kind of a weld mark should fail] if it's busted split tractor at thr rear of trans then unbolt input shaft and pull out and slide coupler out. just did one on wednesday took about 2.5 hr. [with air tools] it's not hard if you have the right jacks and tools. p.s. i did't want to do it but the owner wanted it to be welded again so i put it in a lathe and welded it then turned it down GOOD LUCK if you need more info. just ask
Phil
12-12-2003 17:30:25
 Re: Re: TE20 Shear Coupler in reply to marlowe, 12-12-2003 15:29:11
Thanks Marlowe
I am still trouble shooting. Looking into the panel where the PTO lever is mounted the shaft turns okay through the bearing into the back diff. when driven by the engine but nothing transmitted to the wheels. I can only surmise that the problem lies further back and is not the shear coupling. Even in gear the tractor can be pushed freely with no movement back through the transmission. PTO and hydraulics are fine.
Phil
marlowe
12-12-2003 18:01:08
 Re: Re: Re: TE20 Shear Coupler in reply to Phil, 12-12-2003 17:30:25
when you say shaft is turning do you mean the top shaft or lower one? the top is your drive and lower runs your pto and hyd. if your top one is turning and you can see it going to the rear end then your problem is in the rear and the only access is the rear axele housings on each side of the rear end.if you pull them do the right side first because then you can is the ring and pinion better [sitting on set]
Phil
12-12-2003 19:36:21
 Re: Re: Re: Re: TE20 Shear Coupler in reply to marlowe, 12-12-2003 18:01:08
Thanks Marlowe. The top shaft is turning. I will explore the rear end further.
Thanks for your help.
Phil
