TE20 Transmission Failure
Phil Hancock
12-12-2003 00:45:42
My TE20 has suddenly ceased to engage the wheels, no matter what gear it is in. The PTO and Hydraulics work fine.
Is there a shear pin that may have failed or another problem?
Thanks Phil
rod
12-12-2003 15:48:38
 Re: TE20 Transmission Failure in reply to Phil Hancock, 12-12-2003 00:45:42
could your shifter just be out of the slots easy to check just take filler cap off of transmission and have a look also. My tea 20 had a broken fork in it and had only 3 and 4th gears.
regards
rod
marlowe
12-12-2003 09:22:59
your shear tub is more then likely busted. just did one for a friend in a to-20
David
12-12-2003 01:54:01
I'm 100% certain but I think there is a shear tube in TE20 transmission. You can get a look at it by taking off side cover that has PTO lever on it. I've had a similar problem with a Ford digger that was because differential carrier bearings had disintegrated on one side letting crown wheel drop out of engagement with the pinion. A broken half shaft is also a possibility. I think I've also heard of crown wheel bolts shearing too. I think I'd check the clutch adjustment first as it could have enough grip to drive the pump and PTO (without a load on) but be slipping when asked to drive the wheels. IF PTO also stops with a load on it, that would suggest a clutch problem. If something had sheared you'd probably have heard it.
Alvin n Ms.
12-12-2003 05:24:01
 Re: Re: TE20 Transmission Failure in reply to David, 12-12-2003 01:54:01
A broken axle will have the same results. I would take the trans. top off put it in gear, then bump the starter while watching, alvinnms or ASK Big Dean's Massey Ferguson web site g Dean.
