Valve guide replacement TO-20
STEVE MO
12-10-2003 09:23:37
I have a TO-20 that runs well the problem I have is with the number 2&4 cyclinders. Both foul the plugs badly after a few hrs, the other two are still good. I was told this is valve guides not valves. The question is, can I replace the guides without pulling the head or do I have to take the head off?
Phil(va)
12-11-2003 10:25:28
 Re: Valve guide replacement TO-20 in reply to STEVE MO, 12-10-2003 09:23:37
If the leak is caused by valve seals, not the guides, you should be able to replace the seals without removing the head. Perhaps something to try first....
john(UK)
12-10-2003 16:21:21
You would have to remove the valves and to do that you need to remove the head.
