TO35 Main Drive Shaft and PTO Shaft
Ray A
12-09-2003 17:49:27
The oil seal behind Main Drive Shaft Retainer is leaking on my 35. To get to this seal is it the same as getting to the seal on my TE20? I replaced the seal on my TE20 last spring. I have the 35 split and noticed the leak. Also, the seal on the PTO shaft is leaking. Does this shaft (on the 35) come out the same way as the shaft on my TE20?
john(UK)
12-10-2003 16:17:25
 Re: TO35 Main Drive Shaft and PTO Shaft in reply to Ray A, 12-09-2003 17:49:27
If you would like tha pages out of the parts list to show you what is involved, give me email address or mail me at granada1 at hotmail dot com
David
12-10-2003 10:58:45
Don't know about mainshaft but PTO shaft comes out like T20. (if TO35 is the same as the MF35) Changing seal is easy. To get shaft out I would put an old shaft on and belt it with a hammer to draw it out. There's a large O ring you might need to change too.
Alvin n Ms.
12-09-2003 20:53:18
I had to do mine a couple of years ago, and it is a lot harder job to replace than a TO20 or 30. You will need help from someone that has done the job before. says i alvinnms.
