How to change oil in TO-35 steering box?
Kirk Veid
01-29-2000 09:55:36
I have a 1959 TO-35 Standard diesel tractor. I was wondering how to drain and refill the oil in the steering box. Also, what weight oil should I replace it with? Thanks!
Jim Duncan
01-30-2000 22:04:00
 Re: How to change oil in TO-35 steering box? in reply to Kirk Veid, 01-29-2000 09:55:36
Kirk: The following is quoted from my owners manual, I assume that you have standard manual steering: "The steering assembly has a capacity of 2 US pints of transmission oil. If the oil is low, add transmission oil. Normally, the oil will not require changing; however, if necessary the steering housing will have to be removed from the tractor and drained." The transmision oil recommendation is "straight mineral gear oil, SAE 90 above 50 degrees, and SAE 80 below 50 degrees."
I hope that this helps, Jim.
