No clutch on TO20
walterwilliam
12-06-2003 17:51:00
I just bought a TO 20 but evidently the clutch is stuck. Is there a way to free it without taking everything apart?
Ray,IN
12-06-2003 18:51:45
 Re: No clutch on TO20 in reply to walterwilliam, 12-06-2003 17:51:00
When I got my tractor, Dad had allowed it to sit in the barn for over a year. I freed up the clutch on my TO30 by easing up against a large tree, pushing down on the clutch pedal and the torque broke it loose. The clutch still would "hang", so I used the tree again and slipped the clutch until I began to smell it getting hot. It's worked fine ever since. I had nothing to lose if I ruined the clutch because if this didn't work it must be replaced anyway. The flywheel rusts and it holds the clutch plate fast, slipping the clutch polishes the flywheel and removes the surface rust.(in my case anyway)
Mr Chapp
12-07-2003 05:27:05
 Re: Re: No clutch on TO20 in reply to Ray,IN, 12-06-2003 18:51:45
Another way is, if you have wide open spaces and lots of clear land/ road, start the tractor in high gear, throttle up, work the clutch in & out. This a litle tricky, but so is starting the tractor in gear against a tree. However both methods will work. Good luck, have fun.
