Installing Radius Rods
Ralph-Mich
12-06-2003 04:05:17
When installing radius rods onto the transmission case,should a film of grease or attached dry on the ball ends? My service manual is blank on this install
john(UK)
12-07-2003 08:44:38
 Re: Installing Radius Rods in reply to Ralph-Mich, 12-06-2003 04:05:17
The official factory line on this was NO grease here or on the front axle pivot or on the 3 point linkage balls, it attracts grit and grit wears..BUT its your tractor.
capt.kirk
12-06-2003 07:27:10
ralph i also dilled mine to put in grease fittings.not only does it lube but you can push out dirt that you cant if just lube during assembly
Jerry/MT
12-06-2003 13:23:51
 Re: Re: Installing Radius Rods in reply to capt.kirk, 12-06-2003 07:27:10
I believe that my TO-30 manual says not to lube the ball ends of the radus arms. There is a shim pack on the connector that allows you to remove the shims as the ball end wears. Greasing provides a mechanism to attract dirt which then makes the grease/dirt combination a type of "lapping compound" that will accelerate the wear. Hope this helps.
TO35
12-06-2003 05:15:32
Ralph, I have tried to find any mention of lubricating the ball joint on radius rods several times, but could not find ant mention of this any where. What I do is remove the ball end cap and drill it and install a zerk fitting there so it can be greased it not hard to do. I consider it a wear point( I have seen some caps espically worn) after installing the grease fittings on several tractors i have restored I have monitored them for wear over a period of several years and have found it does help.
best wishes
TO
Ray,IN
12-06-2003 18:55:48
 Re: Re: Installing Radius Rods in reply to TO35, 12-06-2003 05:15:32
The socket should not be greased for reasons already assigned. The front axle pivot should not be lubricated for the same reason.(it is covered in the owners manual)
