Jacking a tractor...
Matt
12-05-2003 15:36:55
My TO-35 which has done a lot of little jobs moving brush, fire wood, some loam screening from the garden tomorrow will finally go to work -- 12" + snowstorm coming in over the weekend.
Worked a late shift in the office today so I could put my shelter back up (blew down in 60mph winds in a storm a few weeks back!), so Smokey is safely undercover from snow.
Now the question:
Went to put the chains on, had a b*tch of a job. I don't chain vehicles often, usually just fire trucks once or twice a year if we even have a winter that bad (although some years I get a lot of practice!). And usually with the duallies we just back the inside tire up on wedge-blocks to make it easy.
Decided since I had to go to work, I'd deal with the chains tomorrow -- they're on but neither tight nor evened out right.
Planning on lifting the tractor up so the tires are off the ground and not pinning the chains in place so I can properly adjust them.
If I block up under the three point hitch well (I have a lot of good oak & chestnut dunnage at home), would it be possible to lift the tractor with the 3 point? Tips? Hints?
I have jack-stands, so I'll put those under the axles to be safe once lifted.
Slow storm, so I don't figure I'll actually start plowing till mid-afternoon :)
Joe in maine
12-07-2003 08:02:05
 Re: Jacking a tractor... in reply to Matt, 12-05-2003 15:36:55
When I put my chains on, I just lay them out on the ground behind the tractor and back over them. When I'm on the center of the chains, I lift each end to the top of the tire and connect. I then work each chain by hand until I can tighten them up. No big deal and a lot safer than lifting the tractor.
danct
12-06-2003 15:03:48
matt
if you ever get the chance you should buy one of the Ferguson jacks that works off the hydraulics,i bought one this year on ebay and i used it last week to put the chains on a 1952t30,this used to break my heart every year but this time it took little time to to the job safely, this thing goes under the axel and lifts both wheels off the ground so you can work like a gentleman,they get a lot of bids when they come up however mine cost near $200
good luck
Tex Ferguson
12-05-2003 19:00:48
Hi Matt,
I never thought about using the three-point to lift the back end; I always thought it descended by gravity.
When I needed a new back tire I did it like this:
built up a crib of 4x4" chunks, laid a couple of 2x8" pieces across the top and put my floor jack on the 2x8's. I placed the jack saddle about midway between the differential and the wheel, and a couple of pumps put the tire off the ground. I had a block ready to put on top of the crib to support the axle when I let the jack back down. When I got back from town with the new tire mounted, my good old TE20 still had his foot in the air, waiting for the wheel. My shop has a grassy floor and a leafy ceiling, so I didn't worry about the tractor rolling off the block in my absence.
Good luck! Tex
john(UK)
12-07-2003 08:51:45
 Re: Re: Jacking a tractor... in reply to Tex Ferguson, 12-05-2003 19:00:48
The hydraulics do lower by gravity, the jack they refer to is fitted under either the bottom end of the link arms or under the axle shaft housing (depends on which one you have) then there is a frame that connect to the upper end of the link arms, as you lift the lever so the tractor lifts. If you want a picture of it email me at granada1 at hotmail dot com
Matt
12-08-2003 11:16:15
 Re: Re: Re: Jacking a tractor... in reply to john(UK), 12-07-2003 08:51:45
third party image
Yep...if I had thought about it more, I *knew* they went down my gravity. But my mind was thinking of the tractor jack as seen in the manual!
I ended up using a standard "floor" and lifting the differential enough to let the tires turn. Chains went on pretty easy.
Plowed the driveway Saturday, with 5".
Shouldn't have bothered, since the snow was light & drifting and Sunday morning I had 14" where I plowed and where I hadn't!
Tractor did a good job. Took awhile for the hydraulics to warm up to work well, but did the job none the less.
Just finishing by the road, about 10 minutes worth of work left to widen the driveway a hair...
And a link broke and I lost the chain on one side. Which since I have bald military tread tires and a small hill midway up my driveway is a problem!
Waying my options of jacking the tractor on my gravel driveway (not very stable!) or otherwise futzing in the snow, waiting till the fresh plowed driveway thawed & froze solid so I could sand, or wait till Wednesday when it'll be 45 and what's left on the driveway will melt...we're waiting :)
Anyway, here's we she rests for a couple days:
john(UK)
12-08-2003 14:25:12
 Re: Re: Re: Re: Jacking a tractor... in reply to Matt, 12-08-2003 11:16:15
Very , very rare we get snow like that fortunately, looks nice but glad its not here in UK...lol Hope you get it sorted soon.
Joe ferguson
12-05-2003 16:27:11
Hi Matt
Just spread the chains on the floor roll the
tractor on the chains..attach the end of the chain
each side of the rim (not were the valve is) forward tractor slowly to permit the chain to follow the tire and reach the other end of the chain and attatch with the hooks.
This way it is possible to install all types
of chains sizes on all types of machinery without
effort..jacks..dirt on your clothes.
The only tool needed is a 2 foot long hay twine or wire.
HTH
Joe Ferguson
Jerry
12-20-2003 17:02:21
 Re: Re: Jacking a tractor... in reply to Joe ferguson, 12-05-2003 16:27:11
The Ferguson jacks that lift the whole tractor don'twork if you have the pins that are needed for the sway arms. I hate to use my plow or blade without the sway arms in place.
