UPDATE on continental eng. parts
souNdguy
11-26-2003 06:33:30
Ok, small update on the parts issue. we got the ring gear off.. had a number on it:
h8c300 w2
and we may have found one through pioneer.
will let you know.
Soundguy
Alberta Mike
11-27-2003 05:57:20
 Re: UPDATE on continental eng. parts in reply to souNdguy, 11-26-2003 06:33:30
That series of engines (the F400 blocks) can have a variety of flywheels/ringears on them depending on what they were used in (which was almost anything). Continental is now called WIS-CON I believe, you can find them on a websearch. If you have the flathead then it is likely either 124, 140, or 162 cubic inches depending on the cylinder bore (all the same engine otherwise). You probably knew all this already but just thought I'd mention it. What sort of shape is the engine in?
