Are TO 20 grille parts available?
Alberta Mike
11-24-2003 09:30:04
Question here again on my friends Ferguson TO20. I've repaired and made a number of the tin grille slats that were bashed in or missing, and the hood and the sidepanels from the front assembly needed work too. The lower section of the grille's center section is missing from the crank hole down, plus the two lower outside panels are missing. If the center section and lower panels were available from somewhere without going to the poorhouse, we'd buy some, otherwise I'll start fabricating replacements.
Paul in Ms
11-25-2003 05:00:39
 Re: Are TO 20 grille parts available? in reply to Alberta Mike, 11-24-2003 09:30:04
Check this site www.dunlophydraulics.couk/ he has all new parts for a te-20 grill . I had asked would they fit a to-20 and was told He thought they would. Some of the other readers might know if they would fit.
Tex Ferguson
11-24-2003 17:45:27
Hi Mike!
Try Sturgeon's Corners in Helena, Oklahoma: (800)345 4456. I have gotten several used and new parts from them in the past, most recently last week. I feel sure they will have the sheet-metal parts you need. Prices are reasonable, too.
Good luck! Tex
Mr Chapp
11-24-2003 16:04:47
This is a question I'm going to ask in the future...HELP...
Ray,IN
11-24-2003 19:42:33
 Re: Re: Are TO 20 grille parts available? in reply to Mr Chapp, 11-24-2003 16:04:47
If you don't mind buying used parts this site will get you started:
