ignition switch
Frank
11-22-2003 13:13:36
I lost my key ring. I thought i had an extra key for my To-20 but can't find it. Can I buy a new ignition switch? Should I call a locksmith?
Thanks
Frank
Scott the ferguson nut
11-24-2003 23:15:38
 Re: ignition switch in reply to Frank, 11-22-2003 13:13:36
Hi Frank
Does your key look like a normal key or does it have two prongs. I can make you one off of my key or I have extra two prong ones. Scott
Phil(va)
11-23-2003 19:09:41
The MF and Ferguson two prong standard key is available at many mail order places like Stevens, etc., and at your MF dealer for very little money. If you need the tractor now, you can jump around the switch with a wire and alligator clips while the key is on the way to you. A (correct) switch will be around $15 or so, and the key is only maybe 50 cents. All those keys are the same, unless you have an aftermarket switch.
ST in Ca
11-23-2003 06:40:01
You can install a toogle switch if security isn't a issue and if it is once in a while you can remove the rotor from the distribitor. These Tractors are easy to hot wire anyway. One of my Tractors have a keyed ignition and if security is a issue I remove the rotor as a back up. ST
Mr Chapp
11-25-2003 17:59:36
 Re: Re: ignition switch in reply to ST in Ca, 11-23-2003 06:40:01
My to just has an off / on switch...Again ...restoration, or every day use? Youre choice, cause there's pleanty of oem parts on this site.
Fred Wolfe
11-22-2003 21:46:30
I can get the 2 prong ignition key. Send email.
TerryMi
11-22-2003 14:37:05
I am sure it would be cheaper to just buy a new switch. Order one from the MarketPlace just to your left listed under Tractor parts. Order today you could haave one before Thanksgiving.
