to30 won`t start
chuck p
11-15-2003 03:50:12
Hi I need help i bought a to30 when i bought the house.it ran fine when the old owner showed me how to operate it.i went to use last week but would not start .i only had 3.5 volts coming out of the coil.i relaced the coil it started up now she won`t.there is a resistor on it but not hooked up.is there a wiring dia. anywhere it is a 12v system.i also replaced the points .020 plugs,
rotor,cap cond. thanks
RC
11-16-2003 12:16:05
 Re: to30 won`t start in reply to chuck p, 11-15-2003 03:50:12
Well Here's a place to start. With a test light If you check the + side of the coil, key on, it should be hot. When you crank the engine over using the key, the -side should blink rapidly. If no blink check the points. Use a screwdriver (w/ key on points closed) and break the the pionts open there should be a spark. if no sand them
I have had a condenser go out. Replace it it's cheap. If the ballast resistor is bad or you do not have one. It should still run. This will lead to shorter piont life. A lot of people remove them when they have a hard starting wore out engine.
Are your plugs fouled? If they are Champions and they are wet(fuel or oil) they are not going to fire.
Are you getting fuel?
Tex Ferguson
11-15-2003 17:53:53
Hi Chuck!
I spent a l-o-n-g afternoon trying to get my TE20 to run after a tuneup -- it would start, but run rough for a minute and then die. Finally I realized the distributor shaft on this model turns counterclockwise, not clockwise like every other engine I have ever messed with. Consequently I had plug wires 2 and 3 reversed on the distributor, so it was firing 1-2-4-3 when it was supposed to go 1-3-4-2. There is a little arrow stamped on the end of my Delco distrib shaft indicating the rotation direction -- just a suggestion, check yours out. Good luck!
Tex
Gary-Miss
11-15-2003 07:27:51
.020 is about right for the point gap, but, she ain't gonna run with .020 plug gap. I go with .032 plug gap. Some of the IH operator's manuals had a misprint with the numbers backward of .023. They won't run on that either. You are porbably supposed to have a ballast resistor, The coil will have that info on it.
john(UK)
11-15-2003 16:34:13
 Re: Re: to30 won`t start in reply to Gary-Miss, 11-15-2003 07:27:51
I have a wiring diagram for that tractor, you will need to send me an email address to send it to though. Should be .022" for the points and .025" for the plugs
Richard B. Wagner
11-20-2003 13:58:49
 Re: Re: Re: to30 won`t start in reply to john(UK), 11-15-2003 16:34:13
I have the same tractor and it went under salt water in hurricane Isabel. I have several things that will/have been replaced. I have not been able to to find a wiring diagram for it. Any Help would be much appreciated.
john(UK)
11-20-2003 14:04:21
 Re: Re: Re: Re: to30 won`t start in reply to Richard B. Wagner, 11-20-2003 13:58:49
Yeah sure I can send one...let me know if it was a 6v or a 12v TO30 and give me an email address to send it to.
