bucket loader is too heavy
Brian
11-06-2003 10:56:49
My 1952 TO-30 came with an "original?" Wagner front hydraulics setup and someones huge homemade snow bucket that weighs a ton and a pretty nice (also homemade) fork lift setup.
The bucket is way too heavy for the TO-30, the forks are nice, but not the right width for most of the wall stones I want to move.
Any suggestions on the "best" bucket or implement for rock moving, shrub moving, etc?
Also, I have a small leak appearing at a connection point on the upper hydraulic frame. Just enough to create a spot on the metal. Is there an easy fix for this?
Thanks,
Brian
Joe in Houston
11-06-2003 11:17:21
 Re: bucket loader is too heavy in reply to Brian, 11-06-2003 10:56:49
I would say the easiest thing for bucket replacement would be to get some plate steel and a welder. You can make one pretty easy as long as you can weld.
You could get someone to build it pretty easily. I have an old WM3 or WM4 Wagner that someone did that with.
Good luck Joe
