Advice on whether to use a snowblower on a TEA 20
Richard Wegner
11-05-2003 20:29:42
Hi,
With winter fast approaching here in Western Quebec I am thinking of trying to use a small snowblower on my TEA 20. I have a neighbour who is willing to let me try out a small 5 ft blower. I would be interested in hearing from other TEA owners who use a snowblower.
I am mainly concerned about the fact that the TEA 20 does not seem to have an extra low gear. It would seem to me that I would want to have the rpms fairly high so the snowblower is working well, but then I would also be going too fast in reverse.
Also in heavier snow it would be good to be able to put the clutch in to stop the tractor but still keep the snowblower turning, but if I do that on the TEA 20 the snowblower will stop turning.
I know that I will need an overrunning clutch, but that does not solve any of the above problems.
Thanks,
Richard
Fergie fan
11-15-2003 17:18:43
 Re: Advice on whether to use a snowblower on a TEA in reply to Richard Wegner, 11-05-2003 20:29:42
We used a blower on our Fergie for several years , an old v-type pull type (Allied ?). We didn't use chains too often , easier on blower and tractor , but you get stuck more often . Not sure about a back up blower , that reverse is pretty fast , no live PTO. Good luck. PS- Still got Fergie , but use bigger blower and bigger MF now
Jim W
11-06-2003 05:21:18
Hi Richard,
I am over here in Eastern Ontario so probably similar snow. I have been using a 6' pull-behind type for the last three years, and all the things you say are correct. (The 6' is a bit heavy and if I were doing it again I think I would go for 5' or 5 1/2'.)
However you get used to dealing with these issues, just like anything else, and it beats using a walk-behind model by a mile. I haven't touched mine since I started using the Fergie.
As far as it driving too fast, it is usually OK when the snow is dry but when the snow is wet you can go as far as possible till everything clogs up, then back off and take another run with the blower raised a bit, till you get the pile reduced.
But definitely get that over-running clutch. The impeller on a snowlower (at least on mine) has way too much inertia to stop by standing on the brakes and it would only be a matter of time before you run into something without it. Two things about that - you can use the ORC as a 1 1/8 - 1 3/8 adapter as well, and, you may have to shorten the snowblower pto shaft as the ORC adds a few inches of length. Regards,
Jim
Richard Wegner
11-09-2003 15:22:18
 Re: Re: Advice on whether to use a snowblower on a in reply to Jim W, 11-06-2003 05:21:18
Hi Jim,
Thanks for responding. I guess not too many folks are using snowblowers on their TEAs. :-) I picked up the snowblower on Friday and it looks in pretty good shape. It is a 5 ft. McKee Sno-lander Model 320.
I will just have to give it a try when we get our first snowfall and see how it goes, but I think backing up slowly and having the auger turning fast enough is going to be a problem.
When you use your tractor in the winter, do you have a block heater for it, or does it usually start just fine?
Thanks,
Richard
Jim W
11-09-2003 16:31:42
 Re: Re: Re: Advice on whether to use a snowblower in reply to Richard Wegner, 11-09-2003 15:22:18
Hi Richard,
I have a block heater but I never think to plug it in, and, it doesn't always start. But, I have a problem with the electrical system where it is charging the battery to not quite a high enough voltage, so it doesn't have much reserve in cold weather. Sometimes I end up boosting it as it runs down in just a few seconds if it's something like -20 degrees. But with a boost, it always starts right up. I really should attend to that regulator.
If the first snow is heavy and wet don't get discouraged; you'll get quite a thrill when the dry stuff comes and you can shoot it a mile.
Regards,
Jim
PS Unless it is an easy winter chains will be pretty much necessary. Today I got one (!) Trygg chain installed. What a job but I think they will really grip.
Harold
11-11-2003 10:39:42
 Re: Re: Re: Re: Advice on whether to use a snowblo in reply to Jim W, 11-09-2003 16:31:42
Try finding a hydraulic driven snowblower and a pump that you can adapt off of the engine pulleys. That way your blower always on the go even tho you are stopped, you could put on a valve system so that you can stopp the blower when you want.
