TO-35
Don Brenton
06-21-1999 06:52:47
can anyone tell me what year my TO-35 is?
serial#169641
it appears to have been painted cream coloured originaly
Paul
06-21-1999 23:53:01
 Re: TO-35 in reply to Don Brenton, 06-21-1999 06:52:47
My source, who worked for Ferguson/MF for 42 years before retiring several years ago, says this: "The original Ferguson TO-35, which came out in late '54 had Gray sheet metal/Metallic Green castings. When the Ferguson F-40 was introduced in 1956, M-H-F decided to make the Ferguson TO-35 the same color as the F-40 (Cream sheet metal /Flint Gray castings). Then in late 1957 or early 1958 the TO-35 went to Red/Flint Gray. In 1960 the TO-35 became the MF 35 and lost all TO-references." During these years it was pretty confusing at M-H-F and it was like trying to figure out "who was on first base."
Thought I'd pass this along for what it is worth.
Paul
Paul
06-21-1999 10:38:19
If your sheet metal was originally cream colored, then your castings would have been Ferguson Flint Gray.
Paul
earl(tx)
06-21-1999 17:32:35
 Re: Re: TO-35 in reply to Paul, 06-21-1999 10:38:19
My TO35, S168189, seems to agree with the unofficial Ferguson website. Underneath the very wrong Ferguson red and flint gray, I can see that the sheet metal was Ferguson grey and everything else (chassis, engine, trans, and rear end) were the dark metallic green specified for TO35's from early '56 through '57. Changed to MF red and flint grey on the '58 models.
Sorry for being so long winded.
Chuck (CA)
06-21-1999 07:51:11
Don, It appears your tractor was produced in 1956.
You might find the following interesting.
(Thanks to the unofficial Ferguson website.)
Chuck
Make : Harry Ferguson division of MHF Model : FE35 - TO35 Category : 3 plow, 37 hp at belt Engine : Ferguson TO35 : Continental Z-134 engine 32,8hp - 4 cyl - 3.3125'' x 3.875'' - Gas Perkins 3-152 engine 35,0hp - 3 cyl - 3,6'' x 5'' - Diesel Perkins A3-152 engine 41,5hp - 3 cyl - 3,6'' x 5'' - Diesel Ferguson FE35 : Standard engine 34,0hp - 4 cyl - 87mm x 92mm - Gas/kerosene Standard 23C engine 34,0hp - 4 cyl - 84,14mm x 101,6mm - Diesel Perkins 3-152 engine 35,0hp - 3 cyl - 3,6'' x 5'' - Diesel Perkins A3-152 engine 41,5hp - 3 cyl - 3,6'' x 5'' - Diesel Serial number : TO35�(1954) : 140001-140005; (1955) : 140006-167156; (1956) : 167157-171740; (1957) : 171741-178215; TO35 Gas Deluxe (1958) : 178216 - 188850; (1959) : 188851 - 203679; (1960) : 203680 - 207426; (1961) : 207427; TO35 Gas Special (1958) : 183348 - 185503; (1959) : 185504 - 203197; (1960) : 203198 - 209483; (1961) : 209484; TO35 Diesel (1958) : 180742 - 187718; (1959) : 187719 - 203359; (1960) : 203360 - 203679; (1961) : 203680; FE35 (1956) : 1001 - 9225; (1957) : 9226 - 79552; (1958) : 79553 - 125067; (1959) : 125068 - 171470; (1960) : 171471 - 220613; (1961) : 220614 - 267527; (1962) : 267528 - 307230; (1963) : 307231 - 352254 (1964) : 352255 - 388382. Notes : TO35 was made in USA. FE35 was made in UK. Ferguson has built 2 versions of TO/FE35, standard and deluxe (who has an independant type of power take-off and has a constant operarting hydraulic lift pump)
Evan MacDonald
06-27-1999 14:19:49
 Re: Re: TO-35 in reply to Chuck (CA), 06-21-1999 07:51:11
The hp figure for the Z134 is wrong, according to my shop manual, it has 34.8 corrected belt horsepower.
Evan MacDonald
Douglas J Ossentjuk
06-05-2000 14:49:18
 Re: Re: Re: TO-35 in reply to Evan MacDonald, 06-27-1999 14:19:49
Hi,
My name is Douglas J Ossentjuk, I have just purchased a "to 35" Massey Harris Fergeson,
I`m new to the tractor business but, have been here in spirit forever. I`m curious about what the two levers out bound of the main 3point hitch operating lever are? they also have the small wheel lock system as the main lever. by the way thanks for the horse power info, on the continental.
