hydraulic system attachements
James Reed
10-28-2003 05:40:47
Just purchased a TO30 and know little about tractor hydraulics. Other than the 3 point hitch , can you add hydraulic powered attachments to the tractor that will run off the tractor's hydraulic system ? For example a 3 point log splitter. If so where are the ports located ? No I have not purchased a manual for it yet.
old professor
10-29-2003 21:35:38
 Re: hydraulic system attachements in reply to James Reed, 10-28-2003 05:40:47
Click on Vintage ads on left side of this page
and click on to-20 operating chart look at "O" in tractor diagram picture for to-20
one port on left of seat other on right. Is it the same on to-30
Barry Reis, Stirling, Ont
10-29-2003 04:57:16
Morning James
I own a 1952 TEA-20 that came with an original Ferguson Manure Loader. The Loader would raise up and down by hydraulics that were controleed with a spring loaded devise that was mounted under the 3-point control that is located on the right side of the tractor, the one to the right of the seat. Send me your e-mail and I will send you some pictures of what Im talking about
Barry
Leroy
10-29-2003 04:57:10
There is a world of difference between a TO 30 and a TO 35, first the TO 35 is a six speed tractor, the TO 30 is a for speed, the information that you have been given is for the 6 speed, not the 4 speed. The TO 30 does not have the plate under the seat, the tap for loader use is at the bottom of the transmission on the right hand side and is a special thread, I can give you the directions to hook up a double action control valve for any double action cylinder including that log spliter but it will be slow. Leroy at [email protected]
Matt
10-28-2003 15:50:17
I'm a newbie to, recently getting my TO-35.
Like others said, there's a small plate under the seat that's the taps.
It's a relatively low flow/low pressure system. Can tell you this, no a log splitter won't work. I don't remember the details from my manual (which I'm sure is very close to TO-30 specs), but I do know that if you need more the 1.5 gallons you'll need an auxillary hydraulic fluid reservoir in what your running.
Indeed for even running front end loaders they put another hydraulic pump off the front of these guys, run by the fan belt shaft. (That's what I have)
My impression is the hydraulics built on these guys from the factory would be good enough to run a small cylinder to adjust an implement's directon, that's about it.
john(UK)
10-28-2003 10:56:52
The hydraulic power output points are directly below the seat underneath the centre axle housing. There is a square "plate",this is the hydraulic pump, on two opposite corners there is a plug screwed into this plate, you can tap into here, but make sure you have the correct adaptor with the correct thread and dont overtighten it.
Bart1957
01-03-2007 18:01:25
 Re: Re: hydraulic system attachements in reply to john(UK), 10-28-2003 10:56:52
Thanks John
I've connected the splitter and it works great. I noticed on another forum that you mentioned using a 15W-40 motor oil in place of the original GL1. Is this oil OK to run during the summer months too? Will this damage any of the brass bushings?
Thanks,
Doug
Bart1957
09-05-2006 18:54:23
Hi John,
You seem to be very knowledgable about the to-20. I recently purchased a to-20 similar to the one I used when I was a kid. It had a manure loader on it and I believe the hydraulics were connected to the plate under the seat. (This was 40 years ago) I would like to hook up some hydraulic equipment to my tractor. I assume one port is supply and the other is for return. Is this a correct assumption? Or do I have it totally wrong. If so, which port is the pressure port? Do you have to put the lift lever in any special position to make it operate? I appreciate any clarifications you might send.
Thanks,
Doug
Jeff
10-28-2003 06:21:23
There is an aux. hydro. port under the seat near the draft control spring. I have never use it so attachment and how to use will need to be answered by others.
