fuel petcock reserve?on?
joe
10-26-2003 13:19:04
petcock for fuel on off and reserve,off is all the way clockwise,where is on and how much do you turn petcock for reserve position? is on all the way counter clockwise?and reserve half way?also just changed motor oil i put 10w30 in is this ok or should i use straight 30?i thought with winter coming i could use 10w30,and in warmer months use straight 30.plus all i had was 10w30. my tractor is 1951 to30. also how much air pressure should i have in front tires? the tractor has loader on it,i have 25psi in them.
Ray,IN
10-26-2003 20:03:32
 Re: fuel petcock reserve?on? in reply to joe, 10-26-2003 13:19:04
The fuel shutoff valve on the filter is set two full turns open for normal gas flow. Completely open accesses one remaining gallon of gas held in reserve. Occasionally you should run on reserve to reduce sediment and water accumulation in the tank. Oil; if your engine has original gaskets and seals the detergents in oil will slowly destroy them. New replacement gaskets and seals are made for detergent oils, however, single grade HD oils are recommended by Harry Ferguson tractor owners manual-20w20 in winter, 30w30 in summer. Tire pressure= 28psi front, and 12psi rear.
TO24424
10-27-2003 17:45:51
 Re: Re: fuel petcock reserve?on? in reply to Ray,IN, 10-26-2003 20:03:32
I'm just going to stop beating a dead horse... Multi vis motor oils, with detergent qualities will not hurt anything!!! Please take a piece of cork gasket material and a piece of rubber impregnated material and soak them both in both oils... This is a scientific experiment.
joe
10-27-2003 16:18:18
thank you Ray.
