hydraulic work slow when cold
jim
10-25-2003 17:06:30
have a 1954 TO-30 ferguson changed tran hyd oil this summer filled with 6 gallion 80-90 gl-1 mineral oil no problem with lift this summer while using 7 foot back blade or 5 bush hog started the tractor this morning about 28 degress went to lift back blade and took long time be for started to lift(about 3 min)and lifted real slow after running tractor approx 20 minutes started lifting normal my question is should i have a lighter grade oil for cold weather
jim
10-28-2003 02:23:07
 Re: hydraulic work slow when cold in reply to jim, 10-25-2003 17:06:30
what is the right oil to use in cold weather?
chris westerberg
10-27-2003 08:50:42
how can you get the hdraulcs to work it is not geting a persure or something
confused
10-26-2003 06:41:52
I'm confused. I thought the "gl" in "80-90 gl-1" stood for "gear lube". When is it mineral oil? When is it gear lube?
CityBoy
10-26-2003 10:03:11
 Re: Re: hydraulic work slow when cold in reply to confused, 10-26-2003 06:41:52
Mineral oil is gear lube. Gear lubes are classified by a set of specifications ranging from GL-1 to GL-7. The specs seem to primarily indicate what additives have been added to the base mineral oil ... anti-foaming agents, anti-oxidation agents, and on and on. Plain old gear oil, a.k.a. mineral oil, with no additives is GL-1.
less confused
10-26-2003 13:07:50
 Re: Re: Re: hydraulic work slow when cold in reply to CityBoy, 10-26-2003 10:03:11
Ahhh...so the 'gl' spec refers to additives and not to viscosity. The '80-90' (in this case) specifies the viscosity??? BUT...90 weight motor oil would be thick as liver SO...is there a different viscosity scale for gear lube mineral oil?
Randy
10-27-2003 22:00:24
 Re: Re: Re: Re: hydraulic work slow when cold in reply to less confused, 10-26-2003 13:07:50
Yes, gear oils and engine oils do use a different scale. It's due to the temperatures they normally run at. Engine oil grades are advertised at the temperatures they nomally run at, about 220 deg F, while gear oils run a lot cooler. So an 80w90 gear oil would be about the same viscosity as a 20w50 motor oil. Universal TDH, Permatran, or Ford 134D oils are thinner and are equal to a 10w20 oil.
glenn
10-27-2003 22:41:00
 Re: Re: Re: Re: Re: hydraulic work slow when cold in reply to Randy, 10-27-2003 22:00:24
thanks Randy. Very helpful info.
Ray,In
10-25-2003 20:30:07
The 80/90 wt. mineral oil will act as you experienced in cold weather. Some use 40 wt straight mineral oil when the weather is consistently below 32*F with good results. Be sure to switch back to 80/90 wt when the temperature rises to consistently above 32*F.
john(UK)
10-27-2003 14:29:30
 Re: Re: hydraulic work slow when cold in reply to Ray,In, 10-25-2003 20:30:07
Hi Ray, This thing about the oil grades again...just how thick is 90 weight? The oil in the back end over here in UK is same as engine oil which is our grade sae 40, because of the different temperatures you experience I know the grades used must be different but how much?...Is the hydraulic oil recommended very thick as it has been suggested or it is just a numbering thing? Our 90 grade oil is what you would use in a rear axle on a truck...quite thick. Your comments as always will be appreciated.
Ray,IN
10-27-2003 19:58:36
 Re: Re: Re: hydraulic work slow when cold in reply to john(UK), 10-27-2003 14:29:30
John, the 80/90wt hyd oil is about the same as 90wt diff oil at equal temperature in U.S.A. It's quite thick because it lubricates the differiental and transmission as well as supplies the hydraulic system.
john(UK)
10-28-2003 10:52:24
 Re: Re: Re: Re: hydraulic work slow when cold in reply to Ray,IN, 10-27-2003 19:58:36
Ray, Yes I am aware it lubricates all the transmission and hydraulics....but are you saying its a lot thicker than engine oil? If this is the case I can understand why the hydraulics operate slowly, we certainly couldnt operate with that over here in UK it would be far too heavy and would make hydraulic response impossibly slow. I know this because we had customers who actually did put gear oil in the system through ignorance and we had to sort it all out. I wouldnt have thought that the higher temperatures you have over there would make such a thick oil necessary. I know this has been discussed over and over again but it keeps cropping up and some of the syptoms just dont add up unless the oil is really heavy.
john(UK)
10-25-2003 19:04:47
80 grade below 50F...are you sure its the proper oil for it and not gear oil you have put in there...its should be little thicker than engine oil. If its heavier than that that is the problem, the pump has to suck it in and if its thick you get cavitation. It will be able to pump it out but cant suck it in.
